color ideas.
J.M.P
color ideas.
Post by J.M.P »
civicex;256369 wrote:haha seriously?
As serious as I can be. Check it.
-2010 Honda Fit
-2000 EBP Civic SI
civicex
color ideas.
Post by civicex »
J.M.P;256373 wrote:As serious as I can be. Check it.
how many can's did that take?
PSN: DumbRands
J.M.P
color ideas.
Post by J.M.P »
15 or so cans. Couple cans each coat, there is like 4 coats. I wetsanded inbetween each coat.
-2010 Honda Fit
-2000 EBP Civic SI
civicex
color ideas.
Post by civicex »
J.M.P;256386 wrote:15 or so cans. Couple cans each coat, there is like 4 coats. I wetsanded inbetween each coat.
are you sure it was only 30-40 bucks?
PSN: DumbRands
J.M.P
color ideas.
Post by J.M.P »
civicex;256388 wrote:are you sure it was only 30-40 bucks?
Yes, cans at walmart are like $2.30 a can or something(or was at the Festus walmart at the time). I already had all the rest of the supplies or my friend had it, the tape sand paper and such, but that stuff isn't that expensive really. The tape is the most.
-2010 Honda Fit
-2000 EBP Civic SI
civicex
color ideas.
Post by civicex »
J.M.P;256392 wrote:Yes, cans at walmart are like $2.30 a can or something(or was at the Festus walmart at the time). I already had all the rest of the supplies or my friend had it, the tape sand paper and such, but that stuff isn't that expensive really. The tape is the most.
oh okay, did you primer it?
PSN: DumbRands
J.M.P
color ideas.
Post by J.M.P »
civicex;256410 wrote:oh okay, did you primer it?
Yes I did, same stuff. Krylon.
-2010 Honda Fit
-2000 EBP Civic SI
civicex
color ideas.
Post by civicex »
J.M.P;256420 wrote:Yes I did, same stuff. Krylon.
Well thanks for info just saved me a ton of money
PSN: DumbRands
civicex
color ideas.
Post by civicex »
did you do it in any specific way cause honestly if you could tell me the steps you took that'd be great.
PSN: DumbRands
99BlackHatch
color ideas.
Post by 99BlackHatch »
FTS EVO;256338 wrote:Not to pick anyone out but look at 99blackhatch's car, you can see its not all even, its just tough to get it perfect. Not sure if your car has the satin clear or not.
No clear was used at all. I just sprayed it out of a rattle can and went on my way. It got the job done for what I built the car to be or eventually be, whcih was supposed to be a track car and i didn't see the point of a nice paint job that would get messed up, but now that Gateway is closed, I just don't care anymore and plan to sell it all.
I currently have the car vinyl wrapped and it worked out well for what it is, but I would just save money and get a decent paint job if I were to do it all over again. But you learn from what you do and what you try. I've tryied many things now, and each worked for the application they were going to be used for.
SquadronOne.net
