Rust removal article (what do you think)
GAWear
Post by GAWear »
Source
There are many reasons for a car to develop rust spots. The main reason is when the paint is chipped or scratched through the primer coat, perhaps by stones on the road or a minor car accident, and the metal underneath is exposed to moisture and air, which causes the metal to oxidize. A rust spot increases and spreads with time, especially with each rain or snow storm. Whether you plan on keeping it or selling it, your car will look cleaner without the rust. Others judge you by your own appearance, by your speech, and by the car you drive, so take the time to remove the rust spots and give the car a painting before the entire car ends up covered in rust.
Steps1Take safety precautions. Wear gloves, safety glasses and a dust mask.(There may be some extreme situations that you may need a respirator.)There will be fine rust and paint dust as well as paint spray everywhere; you don't want it in your eyes or lungs.
2Cover up any parts of the car that you don't want to get dusty. Use a tarp sealed with painter's tape to define your work area. Roll up your windows. The paint dust is extremely fine and will get everywhere.
3Remove the paint around the rust with a grinder. Use a sanding wheel (150 grit) to take off both the primer and paint, as well as any light rust that hasn't fused with the metal, and level the surface between the painted surface and the unpainted area. Feel with your fingers for a smooth surface.
4 Switch to a metal grinding wheel for removing the thick rust and getting into any pits. When using the wheel, go slowly, because these can do a lot of damage. Once this is done apply rust removing acid to the area to remove the microscopic particles of rust that remain. Phosphoric acid is best and can be bought at most auto parts stores. If you want, use a hole spot filler or a body filler like Bondo to even out some of the dents, and fill the space where the paint is gone. Finish off by sanding by hand (120 grit sandpaper) to get a nice smooth metal surface.
5Purchase primer that is ideal for painting on bare metal and find an auto spray that matches the color of your car. Both of these supplies can be found at an auto supply store.
6Prepare the spot for priming. Follow the instructions for your primer. Typically, what you will need to do is:
Wipe the area with mineral spirits or paint thinner.
Tape newspaper on all surrounding areas within three feet
7 Spray thin coats of primer evenly. Spray three coats of primer, waiting a few minutes between coats. Allow to dry over night (at least 12 hours).
8Sand with 400 grit wet sandpaper. This abrasive is specifically made for sanding between paint coats to smooth the surface and degloss, so the paint bonds. Wipe clean.
9 Spray a thin coat of paint so as not to let the paint run or sag. Use as many coats of paint over the primer as you need in order to achieve a nice color and finish. Let it set at least 24 hours before pulling off the tape.
10 Buff the edges of the new paint so that it blends with the old paint. If necessary, apply a clear coat to match of the finish on the rest of the car.
11 Allow the paint to cure for 48 hours. Wash and polish the car. Never wax fresh paint within 30 days of painting!
If you follow the link it has pictures.
How well would this work?
I have a couple spots like this that are rusted but not all the way through just on the surface
CmeltoN
Post by CmeltoN »
its almost imposible to stop rust once it starts...im not saying this wouldnt work but its nature..its hard to stop lol
91beatuphatch
Post by 91beatuphatch »
cant really say you cant stop it. its always cureable. i used to pait professionally, you can do anything with the right tools.
CmeltoN
Post by CmeltoN »
Yeah bit one little spec of rust you miss will eventually grow into what you thought you got rid of when you "removed" it...
Post by 90CivicEx »
yea thats true but they make all kinds of products that can help eliminate that issue if not minimize it. he gave decent info though.
91beatuphatch
yea great info... left a few things out but not much. i always used rust inhibitor and sealed the piss out of it.
Story Worm
Post by Story Worm »
the problem with most rusted hondas and other cars is that the rust is actually building up in the foam of the panel. the foam collects moisture and eventually creates rust. To completely cure a rusted panel your looking at replacing it. you can do patch panels or grind out the rust on the surface and it'll hold up for awhile.
"Life's about falling apart and picking up the pieces"
Lynxs1981
Post by Lynxs1981 »
Story Worm;243035 wrote:the problem with most rusted hondas and other cars is that the rust is actually building up in the foam of the panel. the foam collects moisture and eventually creates rust. To completely cure a rusted panel your looking at replacing it. you can do patch panels or grind out the rust on the surface and it'll hold up for awhile.
Exactly, mostly the lip of the fenders.
