Integra Seats in the EK
Edison Carasio
Post by Edison Carasio »
Looks OE. I like.
98_gsr
Post by 98_gsr »
Those look sick!
Post by RyanA »
Just an FYI: If you want the seats to bolt right in, you can use the inner track from your Civic seat. Just unbolt the Teg inner and bolt the Civic inner on and they bolt right in with all 4 bolts.
I know most people are content with only 3 bolts holding that in. Unfortunately, the one bolt that does not line up is the spot that takes most of the force if you are in an accident with your seatbelt on. The seat will end up pretty mangled and bent up.
Nice looking install.
bemberg2
Post by bemberg2 »
thanks for the heads up, thats what i did, cause i don't want to die. now i need to sell the old civic seats.
Post by Capt'n Obvious »
when i put my teg seats in two bolts lined up but got all four to fit after alot of modification/ spacers/ longer bolts
they sit alot higher than stock
bemberg2
Post by bemberg2 »
my teg seats sit at least an inch lower than the stock civic seats. real nice.
