Spray painting carpet??
Post by Capt'n Obvious »
cyclohonda;195612 wrote:Do you remember what you used? Was it that spray dye that I read about and someone mentioned, how is the condition of the carpet now, like cushion wise? Thanks
oh made it very stiff but still looks good if you do it spray it and after it drys rub your hands ot scuff it in the oppisite direction and respray. you know?
^if its a diff color^
i used i think vht vinyl and fabric spray like 4 bux ill give u the rest of mine. still looks real good after 2 years
95lude_zakk
Post by 95lude_zakk »
for people who dont have time to take all the carpet out can it be done inside the car? and will it work on seats and door panels to?
99BlackHatch
Post by 99BlackHatch »
If you feel safe enough to sit in spray painted material... have at it and tell us how it works out on a hot day on you way to the office when it color changes your pants. Lol
SquadronOne.net
Edison Carasio
Post by Edison Carasio »
Holy f***. Just go to the junk yard and get some carpet.
Post by Clayton »
i spray painted my carpet 6 years ago. its still black.
Edison Carasio
06sik20z3;276765 wrote:i spray painted my carpet 6 years ago. its still black.
Just sounds like a bad idea and a gamble in my opinion when there are other more full proof methods.
99BlackHatch
Edison Carasio;276763 wrote:Holy f***. Just go to the junk yard and get some carpet.
That's what i did... It wasn't hard at all. Easiest swap I've ever done interior wise.
SquadronOne.net
Rich
Post by Rich »
Ive always used rit dye. Spray it on scrub it in let it sit for a day or so rinse it out and if you need to go darker repeat. (only done this when going to black). Just mix it in a spray bottle with some hot water and salt. Wear some crappy clothes. the carpet will still be soft and not hard. And if you rinse it out it wont come off on your clothes. (the stuff is made to dye clothes with after all).
Plus its cheap for a bottle of it at walmart (think 5 bux...) and that should do just about every piece of carpet in the car.
2008 Chevy Slobalt
Hope this helps
Edison Carasio
Rich;276806 wrote:Ive always used rit dye. Spray it on scrub it in let it sit for a day or so rinse it out and if you need to go darker repeat. (only done this when going to black). Just mix it in a spray bottle with some hot water and salt. Wear some crappy clothes. the carpet will still be soft and not hard. And if you rinse it out it wont come off on your clothes. (the stuff is made to dye clothes with after all).
This sounds like the next best idea to replacing it completely. Dye > paint.
Edison Carasio;276770 wrote:Just sounds like a bad idea and a gamble in my opinion when there are other more full proof methods.
fool proof
