Problems w/ the CRX...again.
J8k'S CRX
check altenator
Drowzysleeper
check the continuemtransfunctioner............. or you can get a mock o2 sensor.
IM AN EPIC FAIL
andyjt
You could always just put in a new 02 sensor and try that. Those 1-wire o2 sensors are only like $15 bucks.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
OK, thanks for the help everyone. For an update, the car didn't act up at all today, however, the battery died. I then ran a test on the batt. and alt. at work today, its got a good alt., but a bad batt. I went ahead and got an alt., alt belt, battery and fuel filter from Advance and Huey's Honda just to be safe. Hopefully the problem won't come back. Thanks again for all the help guys. I'd pos. rep you but that went out the window :fag:
