Well, I'm driving home from work tonight and as I'm on my way home, I notice that the car is starting to lose power and sputter. As I start to pull over, the CEL comes on. I turned the car off, and turned it back on. As I drove off, I was able to diagnose the symptoms a little better. No matter what gear I'm in, whenever you push the accelerater past about mid way, the car with sputter and not go anywhere, kind of like its in limp mode. In second gear when you floor it, it will still sputter, but you will slowly gain speed and when you reach 4,500-5,000 RPMs, the car will drive like normal. I checked the code on the ECU and I think its a "Code 1" for Primary O2 Sensor. I checked the conection on the O2 sensor and pulled the hazard fuse for 30 seconds to clear the code out of the system, but the car is still having the same problem. I also noticed that the tone of the exhaust was louder then normal. Do you guys think that its just a bad O2 sensor? My fo-do never had these symptoms when the O2 went bad, thats why I'm asking for your help. Any help or suggestions would be appreciated. TIA
-Rob
Problems w/ the CRX...again.
freakchris03
When i had O2 problems my car would die at every light when i pushed in the clutch...Id say check your spark, and see how clear and bright it is. For some reason it doesnt sound like an O2 problem.
97 Civic hatch...Sold :dead:
sounds like a fuel/spark problem, the o2 code popping cause your car is running either excessively lean or rich. try changing your fuel filter check your fuel pump
freakchris03
Id say do the routine maintance...Check fuel pressure if its fine...move to the electrical side. Dizzy mainly, cap,rotor, plugs,wires..
werd...freakchris03;22417 wrote:Id say do the routine maintance...Check fuel pressure if its fine...move to the electrical side. Dizzy mainly, cap,rotor, plugs,wires..
OK, I know it needs a FF.stolle;22416 wrote:sounds like a fuel/spark problem, the o2 code popping cause your car is running either excessively lean or rich. try changing your fuel filter check your fuel pump
Cap, rotor, plugs and wires were all changed a month ago.freakchris03;22417 wrote:Id say do the routine maintance...Check fuel pressure if its fine...move to the electrical side. Dizzy mainly, cap,rotor, plugs,wires..
JesSi
Catalytic Converter...
Plugs might be fouled out...
BKGuy
id look into a fuel filter ither way, but check and make sure thats the code then if it is id just get a o2 simulator
my cel for my secondary o2 keeps coming on so im just going to get that but i still need to get under the car and make sure everything is still together but its just to dam cold
boner
B-Rad's civic was doing that about a week or two a go and it was his fuel filter.
ROHC THA SOHC-
JonDubya
Could be TPS too, but doubt it.
1997 AIGSR.
Fucking eh cotton!
Fucking eh cotton!
