Crank spin free?
B16aRS
Crank spin free?
Post by B16aRS »
I just got my bottom case together using clamps and equally pulling it together. Now that its together once i put the bolts in and TQ them down doing it the right way (1/4 TQ 1/2 TQ and full TQ. Also why doing that in a criss cross pattern.) The crank seems to tighten up. That isnt normal is it? It should spin free as butter?
Crank spin free?
How tight are we talking about here? Like it takes a little effort to move it or is it a signifigant(say a 4cyl with plugs still in)
B16aRS
Crank spin free?
Post by B16aRS »
Like a night and day difference. Before i tighten it i can spin it and if the rod didnt hit the sides it would do a full revolution. Once i tighten them the only spinning is when my hands doing the spinning.
Crank spin free?
with the housing on is the crank already connected to the tranny? if so is the tranny in gear?
Crank spin free?
btlfed7;188674 wrote:with the housing on is the crank already connected to the tranny? if so is the tranny in gear?
The answer to my question is no.
Looking at your video it looks like his spins free as he puts the flywheel on.
B16aRS
Crank spin free?
Post by B16aRS »
Um no. The crank is just in the bearings at the time being. Not hooked up to the tranny at all. So far i have the tranny assembled, bearings in, crank in, and case together.
Thanks for helping me with this.
Crank spin free?
B16aRS;188677 wrote:Um no. The crank is just in the bearings at the time being. Not hooked up to the tranny at all. So far i have the tranny assembled, bearings in, crank in, and case together.
I am trying, but I have never torn apart a bike motor.
Were your crank bearings good/replaced?
B16aRS
Crank spin free?
Post by B16aRS »
Ya i replaced bearings, seals, crank, and gaskets. Once i get this problem fixed i have a honed cylinder, new piston, rings, clips, head, gaskets, and clutch cover. All this stuff is new.
B16aRS
Crank spin free?
Post by B16aRS »
I went up to donelso cycles today and took the engine up there with me. He looked at the engine and spun the crank and said all is normal. He said its normal for the crank to have resistance when spinning after the bolts are tightened.
