clean setup nothing crazy
Post by Capt'n Obvious »
mock up
1 cube box
iirc 18x13x8 or so
mtx 2 ways front
alpine type s back
type r sub runnin 2 ohms
mtx 4 chan only 2 chans work so its being replaced with a pioneer 4 chan today
thats about it
before
after
replaced the starter and alternator wire the lights dont dim as bad but did not know what to do with the headlight fuse thing
andyjt
Post by andyjt »
Looking nice matt. If i remember correctly i thought the fuses by the battery are for the passive seatbelts, maybe im mistaken.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
Rich
Post by Rich »
definitely need to replace the trunk mat if your going to do all that. Though itd be easiest just to get it all in matching carpet... though if your going to be putting stuff in the trunk at least get something to protect the sub. But decent work so far.
2008 Chevy Slobalt
Hope this helps
andyjt;214489 wrote:Looking nice matt. If i remember correctly i thought the fuses by the battery are for the passive seatbelts, maybe im mistaken.
no its in the fuse box i found it though honda could not
tommygun89hb
Post by tommygun89hb »
bitch'n matt good job
SlowOne.5
Post by SlowOne.5 »
Not bad Matt! Much better than the box you did for the tibby.
Finds it funny you (all) check my profile multiple times a day. Get a life.
SlowOne.5;214789 wrote:Not bad Matt! Much better than the box you did for the tibby.
that was before i knew bout how to make one the next box in tib hit hard with the type r it was 2 cubes and ported i beleive 5x3x16 inch port
4 chan in alpines in and its finished just need a new spare tire cover deal
thanks rob for these
