i just got the block back today from getting bored out so should go together this week..
haha no i wont let that happen..btlfed7;188500 wrote:Looks like a good start. Any worries your little bor is going to outrun you?
JustRob;188524 wrote:Are those...Vitaras? LOL
http://stlhondas.com/forums/showpost.ph ... stcount=14mike93hatch;188531 wrote:yes.....they......are
ummm and? old post, they make oversize vitaras now and longer rods to bump compression jackass. srp pistons are still junk imo.
from FJ ...... LOL...they are custom length to bring the piston to the top of the cylinder instead of 5mm or so below it. bumps compression from 6.5:1 to 8.5:1 ~~SikofFalln;188557 wrote:Where did you get the FJ spec rods from? And are those oversized vitaras?
hey if you hit up d-series.org and talk to fjt dist. they can give you all the specs needed.SikofFalln;188557 wrote:Where did you get the FJ spec rods from? And are those oversized vitaras?
