noregrets;9008 wrote:yes when im stopped it still ticks... with clutch in or out.. but then every once in awhile it doestn click at all...turning doesnt effect it
did you replace the throwout bearing and the pilot bearing when you installed the clutch?
noregrets;9020 wrote:if that is the problem is it alright to drive for awhile??
dont really know if it is the problem or not, but its not really healthy. if the pilot bearing is shot, it can eat up your imput shaft on the transmission and if the throwout bearing is bad, it can eat up your clutch fingers.
