I am located in Missouri. I bought this brand new Jan. 2008. Last car was a 2002 Honda Civic Ex and sold it to get the Mugen.
Mugen is now Supercharged with JRSC 650CC injectors and Flashpro
[ame="http://www.youtube.com/watch?v=pGUa_F4amu4"]YouTube- Honda Dyno[/ame]
Car has been tuned on the following parameters:
• Part throttle analysis
• All Volumetric Efficiency tables analyzed and revised for all degrees and levels of vacuum
• Short Term Fuel Trims analysis and smoothing
• Knock table analysis
• Ignition analysis
• Lambda Overlay’s and Cam angle High/Low fueling
• Cam Angles High and Low
• Ignition Tables for all degrees
• VE Tables analysis (WOT - MAP/SD)
• Throttle Table analysis
• VTC Point is checked and revised based on Flow/Performance
• VTC Window + Pressure analysis
• WOT fueling and knock check.
• Limiter Tables checked for errors and safety margins
• Cold Start fueling and IAT graphing checked
• Overview of potential errors or engine codes if present
List of mods include: (I know the mugen stuff came with the "Mugen Si" but I am listing it as well)
2008 HONDA MUGEN SI #149
EXTERIOR
• MUGEN FRONT GRILL
• MUGEN FRONT LIP
• MUGEN REAR LIP W/ FUNCTIONAL DIFFUSER
• MUGEN SIDE SKIRTS
• MUGEN ADJUSTABLE 3 PIECE WING
• JDM RED “H” BADGES FRONT AND REAR
• MUGEN SI EMBLEMS
• G2 BRAKE CALIPERS PAINT KIT - RED
• TENON 9006 8000K HID KIT
• JDM YELLOW 9005 DRL/HI-BEAM
• SUPER WHITE L.E.D. LICENSE PLATE BULBS
• WINDOW TINT
SUSPENSION & SHOES
• 18X7.5 MUGEN GUNMETAL GP’S
• McGARD TUNER WHEEL LOCKS
• BF GOODRICH g-FORCE T/A KDW 215/40ZR/18
• MUGEN TWIN RING MOTEGI SUSPENSION
• MUGEN SHOCKS/DAMPNERS
• NEUSPEED X-BRACE
• EIBACH ADJUSTABLE REAR SWAY BAR
• CORSPORT REAR SWAY BAR STRENGTHENING BRACKETS
• HFP SLOTTED BRAKE ROTORS
• HFP TRACK BRAKE PADS
• GOODRIDGE SS BRAKE LINE KIT
ENGINE
• MUGEN CATBACK EXHAUST
• DC SPORT 4-2-1 RACE HEADER
• AEM SRI
• P2R THROTTLE BODY GASKET
• JACKSON RACING SUPERCHARGER
• HONDATA FLASHPRO ENGINE MANAGEMENT
• INSTALLED BY 2NRSOFSPRINGFIELD/TUNED BY Vitaliy Mikitchenko
• NGK RANGE COLDER SPARK PLUGS
• RC ENGINEERING 660CC FUEL INJECTORS
• RC ENGINEERING FUEL INJECTOR CLIPS
• INGALLS STIFFY ENGINE TORQUE DAMPER
• YOSPEED FA5 BATTERY TIE DOWN
• COOLANT BYPASS
• MUGEN BRAKE FLUID SOCK
TRANSMISSION
• MUGEN QUICK SHIFTER
• REVISED 3RD GEAR PN-316
INTERIOR & I.C.E.
• MUGEN SI SHIFT KNOB
• MUGEN JDM DOOR SILLS
• GLOWSHIFT 60MM BOOST/VAC GAUGE
• GLOWSHIFT 60MM AIR/FUEL GAUGE
• OEM ALUMINUM PEDALS
• BLACK SHIFTER BAG WITH RED STITCHING OEM
• HONDA OEM ALL WEATHER MATS
• AUTOPAGE FA-110 ALARM
Here is my build page from 8thcivic.com
http://www.8thcivic.com/forums/introduc ... en-si.html
