did you check the bulbs? connection? ground? fuse?Wolf2010;214186 wrote:Well i looked through my manual for the car and it doesnt say anything about that brake light deal.
It doesnt even mention the tail lights
So i have no clue what is wrong
89 Accord Help
crx08
89 Accord Help
stl-imports.com/forums
Wolf2010
89 Accord Help
Yeah i checked everything
The only thing i think it might be is that
There is a sensor like deal in the encloser with my shifter and its making a clicking sound that i have never noticed.
Im thinkg that could be it but i have no clue what it is even called any ideas?
crx08
89 Accord Help
sorry I don't know. maybe someone else would know?Wolf2010;214193 wrote:Yeah i checked everything
Wolf2010
89 Accord Help
I hope someone might cause it is irrating me
This car has been acting wierd since i moved to missouri
In Oklahoma i had no probs
Except for when my water pump went out
Other then that nothing was worng now
Its got the tail light prob
Idling rough
Not wanting to crank right(think its due to the cold weather)
Sometimes after sitting for a day or two wont start period
Its just irritating me
Im hopefully either gonna drop a newer engine and tranny or just sell it
Im hoping to just get the money and drop another engine
Idling rough
crx08
89 Accord Help
Wolf2010;214195 wrote:I hope someone might cause it is irrating me
Idling rough
the housing that hold the bulb could be sticking out causing it not to have any contact with the electrical current. there for it won't light up. I had this problem with a nissan pick up I had. all i did was push the housing that holds the bulb in and it worked for me....I hope this helps
does it drive fine?
does the battery die when you let it sit?
MaSSaCrE
89 Accord Help
Brake light lamp deal is not a biggie. Alot of cars do it and i have had the problem alot, never got it to stop so i just put black electric tape over the cluster where that was.
Id suggest checking for shorts in taillight wires,getting a new strong starter,seafoam your car,and do a tune up.[plugs,wires,oil change,etc] Not gonna get any better without doing some process of elimination
Wolf2010
89 Accord Help
Oh yeah it drives amazing for the year
Yeah i had the battery checked today gotta get a new one soon
Now though the tail lights are fine
So i will hope it stays like that
tommygun89hb
89 Accord Help
Check to see if the e-brake is all the way down. if it is then you may need to ajust the sensor under the e-brake handle. If you have fluid and no problems with the breaks then it is something electrical and not mechnical.
Also for your brake like issue check where the petel contacts the swich on the petel assy.
tommygun89hb
89 Accord Help
as for the manual transmission swap just do a bseries swap any b seires swap would be better than the 89 accord motor
I think the motor mounts for a b series motor for an 89 accord are only 350 dollars.
crx08
89 Accord Help
where do you find that?tommygun89hb;214265 wrote:as for the manual transmission swap just do a bseries swap any b seires swap would be better than the 89 accord motor
