What tires are you dragrace guys using?
Drag radial?
d.o.t.?
slick?
what size?
I've learned alot about tires relative to gearing and hp and was curious as to what leads others to their decisions.
Post up if you have an opinion!
Drag tires?
Drag tires?
Used to use what you guys used to run....205 60 / 13 m&h dot slicks. I want something 24" tall to better match my gearing. All I want to do for now is not top out 4th before the track ends. :PDT_velo:
What secrets have you learned?
Jar Jar Binks
Drag tires?
im going to be running a 275/40/17 MT ET Street Drag Radial on my stock wheel this year i believe....
Drag tires?
I am not going to run full out slicks this year due to my weak diff. Once I swap it out for the 8.8 I might. But until then I will run the drag radials.
Drag tires?
24.5x8x13 mickey thompson e.t. drags
and 225/50/15 bfg drag radials on the street, however im waiting for the et. streets to come out in that size.
Its Pat!
Drag tires?
bfg drag radials in 225/45/17.
spray the way
TEAM AGR: Actual Garage Racing. GMR has nothing.:PDT_002:
96civic cr-v
Drag tires?
i am running 24" m&h Slicks on the track and i had 225/50/15 BFG's for the street that hooked pretty good.... for every day use i say go with the BFG's.
Drag tires?
i use BF DR on the green hatch .. 205/50/14's i belive , they hook pretty good for me but i am going to step up to a 15" rim this year i want to get in the 24-25" inch area
ricedout
Drag tires?
mts track and street tires daily
