Wow I'm impressed! Might have to have him do some exhaust on my camaro lol
2008 Chevy Slobalt Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Hope this helps Yes I own 2 slow red chick cars & 1 real car!
got the -10an fittings and 15' of hose, need to cut the lengths and put the fittings on, still need to order a few -4an fittings and short peice of hose for my turbo feed and some -6 an fittings/hose for lines from the fuel filter to the rail, and rail to FPR. also got my compressor housing powdercoated black.
did some work on the head today
big thanks to Chris(Phate) for letting me borrow his valvespring compressor and also to Jen for running it over to custom sounds where i could pick it up. also thanks to zach for hooking me up with a good 1/8 npt plug, ruined two junk ones but the one i got from him worked perfectly and went right in.
