my 1997 coupe
my 1997 coupe
Post by HardCore97 »
thinking of painting it white, not sure on color just yet though. im open to suggestions.
Racecore.com
my 1997 coupe
Post by Phate »
HardCore97;268516 wrote:thinking of painting it white, not sure on color just yet though. im open to suggestions.
White is always good. I'd do white, or black.
my 1997 coupe
pulled the harness out of the car, got my gsr head back(thanks rick!) now i need to pull off the front end and start sanding the bay and getting it all ready to paint and fix a few things
Racecore.com
Rich
my 1997 coupe
Post by Rich »
Damn guess we will have to run the race cars again sometime corey! :occasion14:
2008 Chevy Slobalt
Hope this helps
my 1997 coupe
got my manifold back from my buddy, had him weld some braces on, going to have him do one more once its all mocked up. then i shouldnt have any problems with cracking due to the weight of the turbo
Racecore.com
my 1997 coupe
Post by 5thgen »
If you do paint your bay the "DIY" way, I would suggest maybe using a paint roller and rustoleum. Thin it out a little bit with some mineral spirits and roll a bunch of thin-ish coats, and use a fine foam roller.
I did this on mine and it turned out decent....it is satin black and is fairly durable.
my 1997 coupe
no real updates other than this
Racecore.com
my 1997 coupe
Post by Phate »
I'd take those back off the car and put it on steelies. Unless you want to do some tractor pulls in the grass, lol.
my 1997 coupe
steelies are on calebs hatch right now lol. il put it on jackstands later today more than likely
Racecore.com
my 1997 coupe
havent updated this in a while, sold the manifold and 38mm tial gate, my 44mm just got here today
took my turbo, downpipe, and a few other things over to rick(5thgen) so he can work some magic on them and getting his old topmount from him. big thanks to him for doing some extra work to make that holset fit on the manifold lol. still need to order a bigger spring for the wastegate, its got the smallest spring in it, will probably go with 1 bar spring or whichever spring is closest to that. come tax return time i should be able to take her to get tuned once everything gets back together!
Racecore.com
