n2hifi aproved sortaflush
Post by Capt'n Obvious »
which is the best pic?
Looks good Matt
J.M.P
Post by J.M.P »
1st pic in that bunch is awesome. I like the bra, the whole car is looking good.
-2010 Honda Fit
-2000 EBP Civic SI
domo is my g meter
when im takng a turn im like go domo go
Rich
Post by Rich »
I honestly im not feeling the extended lugs though to be honest....
2008 Chevy Slobalt
Hope this helps
yeah strong suspension components are so overrated
Rich
Post by Rich »
Capt'n Obvious;232896 wrote:yeah strong suspension components are so overrated
Um well explain to me why lugs sticking out 2 inches more than needed makes it any stronger? A shorter same grade lug that the lug gets as much bite on would work just as well. But I guess if you ever want to run a 2 inch spacer you could! :hello:
2008 Chevy Slobalt
Hope this helps
did not know the stock studs were grade 8 and also there is more threads holding the nut on
also when i put on my wheels it sits flush on the brake hat before i put the nuts on so i dont have to hold it on while puting on the nuts
also the ends being tapered prevents cross threading
Rich
Post by Rich »
Capt'n Obvious;232900 wrote:did not know the stock studs were grade 8 and also there is more threads holding the nut on
Ok you completely skipped what i asked.
Why do you need lugs so long?? Obviously all those extra threads arent being used. Also your not exactly going to be putting down another power to snap the stock lugs off. Unless you have a 300 shot under that hood.
Im putting you down at all im just saying in my opinion its not necessary.
2008 Chevy Slobalt
Hope this helps
went through shiloh last night and 8 cop cars whiped u turns followed me back to back (like me and 8 cops behind me) all the way home 3-4 mi
actually happened the past 3 nights
well i might not put down power but i take turns real fast
