Turbo B16A DA Build
justme5424
Turbo B16A DA Build
Post by justme5424 »
Currently have:
Greddy Profec B Boost Controller
Autometer Procomp Oil Pressure and Boost Guages
Turbo Manifold
Venom 440cc injectors
Walboro 255 fuel pump
T3 Turbo
Tial Wastegate
Custom Downpipe
Turbo XS BOV
Greddy Intercooler
B16A OBD0
PR3 Computer
and now for the pics!
90 Honda CRX HF
-B16A Turbocharged
Turbo B16A DA Build
Post by 5thgen »
just giving you a warning....that manifold has been known to crack under a moderately short amount of time. Keep an eye on the wastegate flange area and the turbine flange area.
And your wastegate appears that it is on backwards.
Turbo B16A DA Build
Post by HardCore97 »
make sure you run an oil restrictor with that turbo as well. unless you want to replace the seals alot. ebay turbos dont like the oil pressure the motor puts out
Racecore.com
Turbo B16A DA Build
good start, as stated there are a few things you might want to watch for.
1. That manifold sucks i would look into upgrading with in the next year or so. google lovefab
2. Wastegate is on wrong
3. Keep an eye on the turbo, check it about once a month for shaft play and other signs of wear
4. oil restrictor
5. Depending on the trim of the turbo it might not be big enough to efficentaly work on the B16. I always read(I am not a turbo expert and I am sure the experts will correct me if worng) that nothing smaller than a 60 trim T3 for a B.
Turbo B16A DA Build
Yikes! Good luck with that.
gsrauto98
Turbo B16A DA Build
Post by gsrauto98 »
alright time to start over, those ebay parts are going to give you headaches later on, i would've looked for quality used parts and pieced a kit together
Turbo B16A DA Build
Post by Gunmetal Si »
wowwwwsers. can i be your first race?
justme5424
Turbo B16A DA Build
thanks for all the support guys.
90 Honda CRX HF
-B16A Turbocharged
Turbo B16A DA Build
justme5424;191386 wrote:thanks for all the support guys.
No problem. Glad we could get the information to you before you learned the hard way.
justme5424
Turbo B16A DA Build
wheres a good place to get a good turbo and manifold
90 Honda CRX HF
-B16A Turbocharged
