Biscut gets a upgrade (56k make me a samich)
eh2_Erik
Post by eh2_Erik »
dang, so it wont be at MM huh?
Now s13_Erik
Post by Capt'n Obvious »
i was going to count the days till you blew it i did not want to jinx it though imo you sould have put the new rods/ pistons in b4 the turbo 250 is too much for a d even if it is tuned well
also do the arrows point to the cam gear or the flywheel
Post by Gunmetal Si »
matt;139898 wrote:i was going to count the days till you blew it i did not want to jinx it though imo you sould have put the new rods/ pistons in b4 the turbo 250 is too much for a d even if it is tuned well
what?????????????
250 is not to much at all actually on a good solid tune , and the built motor wont be going in just yet .. i have a few more things i want to do before i put it in so for now a rebuilt stock d is going back in for now and should be up in a cpl days and with a fixed timing map.
and as far as the arrow's on the pistons they point to the cam gear/ timing belt side of the motor .. where it say's in that = intake and the arrow points to the right.
slammeds2k
Post by slammeds2k »
GUNMETAL SI;139902 wrote:what?????????????
+1000 banish him
Post by Clayton »
stick to what you fucking know and raise your hand before you talk
twkdcd595
Post by twkdcd595 »
06sik20z3;139964 wrote:stick to what you fucking know and raise your hand before you talk
the SLAP! just happened.
ok frankenmotor is in and running , Thanks Rob for the help last night.
let me explain what frankinmotor is first :
well it's obvious from the pics that the y7 bottom was toast without some machine work, and my y8 i pulled from my ek has a spun rod bearing but perfect rings and cylinder walls. So i pulled the good crank, bearings,oil pump, water pump, mains, oil pick up and y7 oil pan and swapped all of that into the y8 block to make one "good" running motor.
i also swapped clutches because mine was about to explode, it started to come apart like dales. I guess the turbo was too much for the oem exedy replacement clutch lol so i am using a act 6-puck right now. I also flushed my clutch line because the fluid was NASTY , black and nasty smelling ...but it's all new and clean now and the clutch works so much better. While the car was down i also redid my wiring harness and relocated a cpl things and eliminated some brackets, i need to finish a few more things but it cleaned up the bay alot. I finally installed my GSR front sway bar also .. i figured 4 months was long enough to wait lol
i need to fill the tranny and put coolant in it and then switch base maps
but here are sum pictures
the bottom end installed waiting on the head:
My redid wiring harness:
the head back on and the motor ready to go:
Old Nasty break fluid from the clutch line:
And new stuff ..ah much better:
thanks for lookin
I'm glad I could help out again. Lets get this thing finished up for Starved Rock!
99BlackHatch
Post by 99BlackHatch »
Fucking right
SquadronOne.net
