+1 after looking at some peoples plans a sohc D can do some damage to a B for under 2000 or so.SilverStreak;34738 wrote:BHAHAHAHAHAHAHAHAHAHAHAHA...Never underestimate the power of a single slammer. Why throw your money away on a swap when you can make the same power for less money?
PICS: dabeastwthn's build
Dabeastwthn
Plus why spend the extra $$ when I got a pretty good swap sitting in it already that I didn't have to pay for. :drive:
2000 Accord 5spd Coupe
runsonrice
Piss off Corey.90CivicEx;34715 wrote:lol take it to the callout's section
black94sol
question?? ^^^black94sol;34552 wrote:looks good chris...but i have one question.
due to the difference in deck height, would you need to change to a different timing belt?? because most d series combos use different timing belts...
just a thought on your idle issue
am i wrong...someone explain if i am
I ♥ my Honda | dSoc #29
01 CRV AWD SE
Its not a hobby. Its a way of life.
01 CRV AWD SE
whenever you do a mini me swap on a d15 its a good idea to get an adjustable cam gear. if you install a z6 head on a d15 bottom end the timing marks will be off about 4.5 degrees this can cause idling issues not to mention timing issues. i have heard a y7 cam gear fixes theses issues also. yes, a different timing belt is required either a y8 or z6 belt....black94sol;34552 wrote:looks good chris...but i have one question.
stolle your correct on the timeing gear issue, when chris got the car it had a adj cam gear on the d15 so when i swapped the heads to the d16 i also swapped the cam gear. this way i had adjustability to help get the timing correct, but after spending a hr adjusting the cam gear i was never able to make the idle issue any better but i finally got a map code out of the ecu so i am going to try that next.stolle;34900 wrote:whenever you do a mini me swap on a d15 its a good idea to get an adjustable cam gear. if you install a z6 head on a d15 bottom end the timing marks will be off about 4.5 degrees this can cause idling issues not to mention timing issues. i have heard a y7 cam gear fixes theses issues also. yes, a different timing belt is required either a y8 or z6 belt....
i was able to reuse the (brand new) d15 belt with the z6 head, the belt is a 223 and the z6 belt is a 224, technially either one would work but since the 223 is recommended i just stayed with that.
Dabeastwthn
I appreciate all the help Chris and everyone else that's helped too....Glad to hear it's going pretty well. Can't wait to get back this weekend and see where your at then. :blob3:
Dabeastwthn
Ahhhh...the damn motor is shot...this sucks!....Sorry just had to vent! :violent5:
what???Dabeastwthn;37019 wrote:Ahhhh...the damn motor is shot...this sucks!....Sorry just had to vent! :violent5:
Motors shot? I'm confused, but in anycase pull the head and lets change the block
