work being done:
z6 head install (previous JDM d15b head had a bent valve)
wire up vtec (car is a dx so no factory vtec wiring)
vafc install
water pump
timing belt
fix driver side motor mount
swap front and rear bumpers
remove 2 wheels stuck on car due to no lock removal tool
pics from yesterday and today
pulled the d15b head
correctly installed motor mount
new head gasket sprayed with copper gasket sealer
Z6 head installed with head studs
valve cover installed and finish hooking up all the wiring
ok motor fully back together minus airfilter lol and it RUNs
ok thats as far as i got tonight, motor euns has a cam timing issue so the idle is poor but it runs and revs up, going to swap cam gears tommorrow and retime it so it should fix the idle issue then on to the rest of the project
