how do you install bi xenon 9007 hids?
sirricealot
Post by sirricealot »
heres the pic of it.
the h11 for my fogs was pretty simple but now they threw in an extra harness and im confused. Any help is appreciated.
thanks.
xbxlive: sirricealot07
ps3: sirricealot7
David Runyon
02Type-S
Post by 02Type-S »
Do i see bare wires on the hi/lo harness?
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
sirricealot
02Type-S;285463 wrote:Do i see bare wires on the hi/lo harness?
Waffles and google helped me out.
The bare wires is so you create your own blue plug, 9004 is wired different than a 9007. pretty much this could be for 9004 if i rewire the blue spade plug.
Got it all hooked up and they work, very bright, except i found when I have my car on, idk if its bc my hood is up and the sensor is partially possibly covered, but my lights turned on automatically. I searched for the drl issue and my 06 apparently doesnt haave a drl fuse, even tho i do have the parking lights during the day on.
does that count?
thanks
ps3: sirricealot7
David Runyon
02Type-S
Post by 02Type-S »
If your DRL is in your parking lights you are fine. Its only a problem if the DRL is in the bulb that will be changed to HID.
2002 Acura TL-S
sirricealot
02Type-S;285467 wrote:If your DRL is in your parking lights you are fine. Its only a problem if the DRL is in the bulb that will be changed to HID.
well drl was in my parking light, but for some reason my headlights come on now when i start the car. its supposed to be auto headlights.
ps3: sirricealot7
David Runyon
02Type-S
Post by 02Type-S »
Interesting. lol
2002 Acura TL-S
sirricealot
Not sure why but it's annoying. My yr is said to not have drls but I do. Maybe I need to take the parking light fuse out? I don't have a drl fuse
ps3: sirricealot7
David Runyon
02Type-S
Post by 02Type-S »
sirricealot;285475 wrote:Not sure why but it's annoying. My yr is said to not have drls but I do. Maybe I need to take the parking light fuse out? I don't have a drl fuse
A weak ground can make these kits do crazy things, if at all possible, ground to negative battery terminal once you are positive everything is hooked up properly.
2002 Acura TL-S
sirricealot
02Type-S;285476 wrote:A weak ground can make these kits do crazy things, if at all possible, ground to negative battery terminal once you are positive everything is hooked up properly.
a bad ground would make it turn on automatically no matter what? i am able to shut them off.
btw there is a ground for each headlamp, one is grounded on a huge engine ground on the driver side and the other ground is on the fender bolt. The wire for the ground was super shortt.
ps3: sirricealot7
David Runyon
Potts1
Post by Potts1 »
When I helped out putting my brothers in, we just bolted the grounds to where the radiator bracket bolts to the radiator support.
-Potts
