Well i decided to take a really in depth look at my teg today and figure out what all i had going on and see what id have to seek advice on fixing.
First....i found im running a p75 ecu on my b20 VTEC....so no wonder my vtec isnt engaging.
Second....my i hear tapping n the head. i had Sharpie and couple other guys take a look n listen and everyone says i need to get my valve lash adjusted.
Third.....my cruise doesnt work...but the fuse isnt blown so im guessing the harness is hacked up somewhere.
Fourth.....im running a gsr head, with a gsr intake(iabs)....with the p75 ls ecu.....but im not throwing a check engine light....so im guessing the light has been pulled unless that wont throw a code(correct me if im incorrect)
Fifth....my reverse lights dont work...neither of them, but the fuse is fine. havent checked bulbs but i figure what r the odds of them both being burnt out?
...as it sits, i miss my lude...but i never been one to cry over mistakes i've made so any help to fix these issues will b helpful cuz again...im new to the civic/integra chassis.
Time for progress
92_luder
Time for progress
fry
Time for progress
turn your ignition to "on" and see if your check engine light illuminates for 3 seconds, that will tell you if its been pulled out
muha22752
Time for progress
I would swap the entire harness, that will save you headaches in the furture.
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
W.K.D
MaSSaCrE
Time for progress
Change all fuses even if the appear to be good. Did that in the 240sx I had and all types of shit started working that had "good" fuses already in use
Turtle_Civic
Time for progress
Use a test light and make sure both sides have power on the fuse. No since in changing all of them.MaSSaCrE;282838 wrote:Change all fuses even if the appear to be good. Did that in the 240sx I had and all types of shit started working that had "good" fuses already in use
Real men dont lift the front wheels.. They power them!!
92_luder
Time for progress
i actually was wantin to do this...jus to save myself headache....and i kinda wanted to minor tuck too, pm me with a price for you to do it and for the harnessmuha22752;282837 wrote:I would swap the entire harness, that will save you headaches in the furture.
92_luder
Time for progress
tryin nowfry;282835 wrote:turn your ignition to "on" and see if your check engine light illuminates for 3 seconds, that will tell you if its been pulled out
Time for progress
most of your issues seem related to the swap
- check and make sure the reverse wires at the tranny are hooked up (prob why your lights dont work)
- does the sruise power up (green light) if it does but dosnt work it may be the brake wire or the clutch switch for the cruise is bad ...easy fixes
- if your running a ls ecu with a ls harness then you wont throw any codes, mainly because the ecu dosnt know that there is a vtec head on the motor... but when you put in a vtec ecu on the ls harness you will throw codes... you need a p72 or p28 chipped for a gsr then pin the ecu for vtec and run wires to the vtec solenoid after that then your ecu should work fine... Or just buy a vtec controller lol
these are all simple issues common with a swapped car
andyjt
Time for progress
92_luder;282826 wrote:Well i decided to take a really in depth look at my teg today and figure out what all i had going on and see what id have to seek advice on fixing.
I asked you this before in your other thread. Im pretty sure it was an old car of mine. Double check. Is/Was this car an Auto originally?? If its my/my friends old one like im 99% sure the Reverse lights arent wired up after the auto-manual swap.
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
muha22752
Time for progress
HA, I wish! I want Chris to help me with mine, maybe after that.92_luder;282844 wrote:i actually was wantin to do this...jus to save myself headache....and i kinda wanted to minor tuck too, pm me with a price for you to do it and for the harness
umadbro?
W.K.D
W.K.D
