Forza 4 Tuning and Other BS
muha22752
Post by muha22752 »
Like Josh suggested here is the new thread.
Edit: This is for A class.
So my friend Kevin tuned a R33 that ran 59 sec on scuba(i know that is miss spelled). for the life of me I cant seem to get my R33 under 1.01, I have tried everything in the world and I am out of ideas. anyone have any suggested set ups? I am also playing with the benz 190E, and a few other cars but I still cant get under a min.
Oh and has anyone on stlhondas started a car club?
umadbro?
"You have to pay to play"
W.K.D
1995 Civic Si 1.6 (Sold)
2003 Audi A4 1.8t (sold)
Post by 5thgen »
May want to say what class the car(s) are in.
I haven't messed with much suspension wise other than toe.
I always lower the car the lowest without bottoming out (I sometimes keep the rear a little higher to help traction on the front wheels....don't know if it works well or not.)
I don't know a sweet spot for spring rates, shock bound/rebound. I can't tell the difference as well as I can with changing toe.
I usually keep my LSD numbers low ( in the 20s or 30s).
I try and keep toe out on the front, in on the back, on the tighter courses.
It helps turn in a decent amount.
Post by budget_crx »
I have never played forza so I don't know what is adjustable, but could you explain how the car is driving? What is the weight and HP? Perhaps I can duplicate it on GT. lol
muha22752
Post by muha22752 »
it is driving great. to be honest I have no idea what the problem is. it is about 412hp, 3300 lbs I think.
umadbro?
W.K.D
sharpie
Post by sharpie »
Can you shave weight? Idk what class restrictions are but 3300lbs seems heavy
muha22752
Post by muha22752 »
I will check exactly what the set up is when I get home.
umadbro?
W.K.D
Post by 5thgen »
I am having a hard time finding r33 in the leaderboards for tsukuba.
Any skylines that are 1:03.5 and faster are r32s. Doesn't mean the r33 can't go faster, but like I said, 2000 entries and no r33s.
I am trying this myself....3300 is no weight reduction or 1st weight reduction.
I think the fastest way with the r33 is to convert to rwd.....you lose a lot of weight as well as drop about 50 points in class.
Post by 5thgen »
Anybody know if using the clutch makes the car faster?
Almost all of the top leaderboard people (probably use a wheel as well) use "full throttle shift".
ryansDc5
Post by ryansDc5 »
I haven't tried clutch yet, does full throttle shift indicate they're using the clutch?
'05 NFR s2000
Post by 5thgen »
More than likely. When they reach their shift point the car redlines for a bit.
I'm going to try it on a half mile track and compare.
so here are my results with an AWD car
manual w/o clutch 18.30 avg.
manual w/ clutch 17.90 avg.
Just on a half mile track, going through 5 gear changes, saving 4 tenths of a second. That is a pretty big difference for 5 shifts.
Went back to tsukuba with a lotus exige and manual w/ clutch and barely got under a minute with a 59.94. Upshifting isn't bad....but it is hard for me to downshift using the controller....so I just normal downshift and let it grind the gear.
