Ok, so here's a list of what's missing so far:
My B16 Engine with Blox turbo manifold. Looks like this:
has silver AEM cam gears, GSR cams, ARP headstuds, and a REALLY thick headgasket (looks like 2 stock ones stacked). will be needing a water neck, since they dropped it and broke one of them. I still have the piece they left behind. Had a stock intake manifold painted to match with a Hondata IM gasket, Golden Eagle Sandwich plate, and the oil pan is stock with a Russell Black anodized 10AN bolt on fitting mounted on it. It has a brand new distributor from Oreilly's on it, but was missing the cap/rotor. Basically, even if they strip the motor down to bare aluminum, there are markings on it that I can identify.
Stuff taken from Lito's car:
2 Alphasonik amplifiers. they are simple looking silver amps with analog hour meters on them. Look like they have tiny odometers built in. they look similar to this:
Also, they took the indash portion of his Eclipse foldout headunit. They cut the DIN cable, so it's useless. OBD2 H22 prelude manual ecu (x2).
Other parts missing from the shop (still doing a full inventory, so this is not complete):
10,12,&14mm Snap-On flankdrive plus ratcheting wrenches
12mm Snap-On flankdrive plus combination wrench
2 Blue-Point ball peen hammers
Virtually new in box Rockford Fosgate 360.2 signal processor
used Rockford Fosgate 551x and 551s amplifiers. They both look like this:
set of MBQuart 6.5" Component speakers...they are old so I don't recall the model number. But they are still in the box. Plus, there's an extra set of MBQuart add on tweeters still in the original box.
Speaker box with 2 JL Audio 10w3v2 subs. They have the JL Audio grilles on them too.
Blox LCA in Black for 96-00 Civic
Skunk2 Pro series Cam gears NIB for B/H series
MSD distributor cap for B series external coil
BNIB Autometer -30-+30 mechanical boost gauge Ultralite series.
Here's the real kicker: it has to be someone that knows me fairly well, has been in the shop often, and possibly has access to a key.
the things that were stolen are very specific and some of them were not in plain view or even easily found...so they had to have been in the shop before. No windows were broken, no locks smashed, and no doors pryed open, so maybe has a copy of a key somehow.
I will update with any more items or info as I get it. If you come across ANYTHING you think pertains to this PM me or call my cell 573 576 2451.
Ben Brotherton
