This was the best money I have spent in a while, just put these on. WOW, the old ones end links where trashed (on the Focus they are like a rod with a ball joint on either end). Such a dramatic improvement honestly.twkdcd595;296128 wrote:Ordered MOOG upgraded larger greasable front swaybar links for the Focus. Will put them on when they get here and replace mine. Should be an improvement and also get rid of a bit of a clunk in the front suspension they are notorious for creating.
twkdcd595
Andrew
Picked up an intermediate shaft for the Integra, my parts list is getting smaller. Really wanna get the motor/tranny in soon.
crimsoncivic
Well went in to change my timing belt, tensioner, and water pump.....saw my oil pan gasket leaking and wouldnt u know I'd have a suprise in there when I took the pan off.....gotta redo the entire bottom end bearings so I'm just gana go all out and redo everything new rod bearings and thrust washers and crank bearings Yay fun more experience and motor work hahah...
a work in progress-
New tires on the Volvo today. Ordering iPod interface for factory radio for it tonight.
lurch95hatch
New plugs, wires, cap, rotor, and trans fluid in the hatch
92_luder
new speed sensor n oil change
Picked up a factory cargo cover and the roof rack cross bars for the V70T5. Drove to Collinsville, IL this evening and bought another Volvo; 2001 S80 T6 with brand new transmission. Will look it over once it's daylight to see what kind of issues it has. Pretty sure it has a charge tube off of one of the turbos as it's throwing a P1238 code.
twkdcd595
Regreased the new front swaybar links on the Foci and changed all the lugs on it to matching tuner lugs (had a bunch of mismatched bullshit before) I use to have on the Accord.
Changed all the lug nuts on the Accord to new Muteki Sr48 open extended lugs and got rid of the ugly chrome tuner lugs I had.
95_gsrfodo
installed ac bracket, ac compressor and chared the syatem.. make and installed a shifter extention, added stickers for horsepower, fixed the radio so it works at all times now... aklso removed all the old window tint residew as well
4 Doors = More Whores
