Edison Carasio
Post by Edison Carasio »
Got the four door to run, just won't start on it's own. :(
gcef89
Post by gcef89 »
got the front part of my gf's rex primered welding in patch panels tonight!
riceROCKET
Post by riceROCKET »
I Leopard Printed duck tape my front lip. *Swag Me the F*ck out* :foshizzle:
Affililated with the "Anti-Wheel Gap Association" because that ish is ugly :spank:
4Door
Post by 4Door »
dropped off the Z6 to get the rotating assembly put together...
cant wait to get the 92' up and running again :)
H.E.A.R.T
Uncle_Willie
Post by Uncle_Willie »
Put Peel and Seal on my two front doors of my sedan and put different speakers in the rear deck. Slowly trying to reduce road/exhaust noise and upgrading the stereo system without spending too much.
1992 Civic Dx Sedan
l D15B Vtec l Tucked l lowered l Fit Sport Wheels
Cman46290
Post by Cman46290 »
Replaced the O-Ring to the power steering hose that connects to the top of the pump... has been leaking for some time... also washed the engine bay after~
1997 Acura Integra GSR
Intake
Header
OBX Exhaust
Rota Boost Wheels
ALL MAINTENANCE
iStick
Post by iStick »
[FONT="Georgia"] I just put in a new radiator & slave cylinder my other ones were leaky.. . Also waitingon my new tie rods & ball joints I order off ebay to arrive to install.. .[/FONT]
93Ludetta
follow me on twitter @ScanMyBCode
:honda:
Smiling Shadow
Post by Smiling Shadow »
got my 95 civic with the b20 to start for a min using some d series bs, least motor sounded solid still have alot of parts to track down thou i'll be hittin the yards tomorrow look for a teg as a donor:pals:
4Door
Post by 4Door »
Smiling Shadow;278539 wrote:got my 95 civic with the b20 to start for a min using some d series bs, least motor sounded solid still have alot of parts to track down thou i'll be hittin the yards tomorrow look for a teg as a donor:pals:
not sure if there still intact, but pick n pull had a couple of Teg's with the motors still in them...
H.E.A.R.T
twkdcd595
Post by twkdcd595 »
Accord's new fuel system is completed finally and tested for leaks!
