changed out some bad valve stem seals so my smoke show will go away.
changed the oil
v-tecivic
97 civic ex turbo
13.1@112
schmoses
changed out the burnt out bulb in the gauge cluster and went and bought a donut gasket for the ebay el cheapo header I bought to replace the one currently on the car that I put a hole in.
LEGEND
Holy shit dan ypu have been wheel whoeing it up!
1993 Acura Legend LS 6spd Coupe
crazysol
Didnt improve, but i will be improving now that the front is f****d
I gave LEGEND a ride on some backroads.....Smashed a small animal at speed.
He got scooped up into my grill, hung out there for a few hundred feet. Then, when i hit a dip, the animal fell out and rolled under the car..
Bent lower core support, Grill and license plate ripped out, Smells like crispy critter...
Shitty
Shitty
Barn-Yard Built..
HatchGirl89
Got new tires, expecting to get my new cv axel and outer tie rod this week and fix it(:
mild83
Cleaned my k&n, lol
onecam12sec
I finally vacuumed my car, getting ready to have it tune before my trip to fl
twkdcd595
Cleaned the air filter on the short ram of the civic last week.
Today much thanks to Rick since he did most of the work and I assisted!
Civic finally has a 100% working trans with no more 2nd gear poping out and all good syncros! Also did a complete new OEM replacement clutch, mine was on its last leg. While doing that stuff gave me a chance to window weld fill the torque mounts and engine mount on the pass side.
I did a tune up, oil change, tire rotation last week before I went to Atlanta. On the trip, my rear struts blew.
Ordered new struts all the way around, and some toe rods.
stlskater92
New stage 3 clutch and 11.5lbs flywheel (stock is 19 :BangHead: ) Eibach springs and a good washing because it sat under a fruit tree and got pollen all over it last week :SuicidalSmiley: but that looks like it will become an everyday occurance over summer with the new house
