SweetEBPSi
Post by SweetEBPSi »
STi tranny mount, race crossmember bushings, race rear diff bushings, and a axle back exhaust put on the WRX.
Kendale
Post by Kendale »
JustRob;245181 wrote:I officially purchased my new shell.
Nice man about time you got a honda again.
LimeKillerSi
asdf
Post by asdf »
Fixed all problems causing CEL's.
Ordered new coilovers.
Bought a new head unit.
Post by Phate »
asdf;245282 wrote:Fixed all problems causing CEL's.
Why arent you saving money for my motor?!
I did my oil today, rotated the tires and was going to do brakes.. but the pads still look like new on the car.
twkdcd595
Post by twkdcd595 »
Over the last week or so. Replaced the first o2 (thanks clayton for a used o2) with a good one. Repinned the 2nd o2, guess I retarded out when I made up that one. I replaced the fuggered front struts over at ricks while rick pulled apart the trans to give it a look (thanks rick)... finally good suspension all way around car feels so much better. Plugd a screw hole in one of the new rear tires on the car. Oh finally... cut up my the already hacked Injen cold air on the car while we were putting things back together to make a short ram like I wanted, took a whole 2 minutes but looks perfect now.
aGUNS
Post by aGUNS »
I replaced the crankshaft positioning sensor in my S10.
SikofFalln
Post by SikofFalln »
Installed a K-teller 3" exhaust with a 2.5" to 3" car-sound cat. The car is now loud and annoying. blah... But it has a cat, so it will pass emissions!
3-1-4
v-tecivic
Post by v-tecivic »
changed the oil, and installed my new dual bend short shifter. feels great not having a bunch of play in the shifter.
97 civic ex turbo
13.1@112
twkdcd595
Post by twkdcd595 »
Speaking of passing inspections, civic finally showed a readiness codes on the sensors as I have been driving it for like a week waiting for! Passed the OBD/ emissions check, already passed safety.
Time to get some proper plates for it. Sold my beater Altima so its officially the new driver.
Liquor Assassin
Post by Liquor Assassin »
better then oem (semi-new) clutch, new throwout bearing, fixed starter issue, new tourque rod mount, soon to be aligned and a new set of tires spells new life for the hatch
