crx08
put bigger brakes on red accord using stock parts. changed the fuel filter. oil pan gasket and oil. and main relay few weeks ago.
stl-imports.com/forums
chunney
Took the rear drums apart, again, bled the brakes, again, adjusted the e-brake, again. Greased everything in the drum. E-brake works amazing now.
luvmyhondas
fixed my wiring harness. ordered 4bar MAP sensor and Hondata Boost control solenoid. Also, got some heat wrap for the mani, DP, and WG dump.
AKA audioguru76
79 Hondas and counting!
I actually did this stuff last week, but i havent been home to post up pictures.
Was going to a car show over the weekend so i decided i would finally do a little work to my car in the stereo department... as a car audio installer i really never care what my stereo "looks" like, i cared more that it works and sounds good ... but i always bitch about how it looks like shit everytime i open my trunk so.....
what i started with lol:
my old box (has had atleast 4 faces on it and 8 different woofers/configurations)
-so i stripped everything out and then threw a new box together made some trim panels, threw some material on everything and this is what i ended up with after a cpl hrs work.......nothing crazy just clean with plenty of room to carry stuff around still
and if your wondering were i moved the battery to ....
excuse the amp, it's a temp till my amp comes back from service .. ill finish behind the seat then also
I also put on my nardi that ive had for about 7 months now lol
chunney
Damn chris looks good! I may have to get ahold of you when it comes time to redo the enclosure in my car. I'm not quite sure what I'm wanting to do yet but I got to thinking and basically...
Big sub box + back of crx + accident = probably won't be pretty.
just let me know, i can make it look how ever you want
here is a picture of one i did recently for a single 10 and the amp hidden in the storage area
91beatuphatch
meh got it impounded...:BangHead:
bks
replaced my window runner seal... in doing so I broke my b pillar garnish (exterior door)... but my window rolls up and doesnt fall off track and it seals as if it were new!
next on my list...
yonaka exhaust $260 looks and sounds just like ws2/sp2
replace the [hard] brake line i messed up when i did my rear disc
replace the [soft] brake line i kinked when i did my swap
next on my list...
02Type-S
Put a battery in the TL-S and had a flywheel resurfaced for the Integra
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
2002 Acura TL-S
