Installed my new p:JDM 3 pt brace, and hood dampers.
T-Rock
Got my car finished finally still have some bugs to work out.
Je forged ceramic coated pistons 8.5:1cr
L32 connecting rods
arp rod,main,head studs
Clevite rod,main,cam bearings
Machined align bore honed and balanced
ATI harmonic dampner
oil volume kit
secret big boy cam
stage3 cnc ported heads
Manely oversized valves
Manely 150# valve springs
Manely titanium retainers
Gasket matched LIM
Intense 1.75in intercooler core/pump
ported gen5 sc
2.8in pulley
LS1 throttle body/85mm maf 5wire
Yella Terra 1.6 solid roller rockers
comp oer roller lifters
comp magnum custom length pushrods
42# lucas injectors/ need bigger ones though
TOG headers
New built trans with 3.29 gears and a precision torque converter with billet back plate, and a bunch of other little stuff that needed to be done.
L32 connecting rods
oil volume kit
secret big boy cam
Gasket matched LIM
ported gen5 sc
2.8in pulley
TOG headers
Lowe Performance
Dan The Man
Officially took every aftermarket part I installed off of my Civic
team NOCO crew member #4
Currently Taking A Break From The Game
got the 90 running
put the track rs on the 94
and changed a tierod thanks brian
andyjt
Week before Expo = crunch time!
This week: Upgraded Rear brakes, all sway bars, new strut tower bar in the rear. Windshield mouldings. Swapped out wheels. Cleaned up some wiring. New tires, alignment, and a few more things to come this week
New Tires:
New Tires:
-Andrew-
'00 Honda Civic Si
'91 BMW 850i
'00 Honda Civic Si
'91 BMW 850i
twkdcd595
NICCCCCCEEE!!!T-Rock;237495 wrote:Got my car finished finally still have some bugs to work out.
L32 connecting rods
oil volume kit
secret big boy cam
Gasket matched LIM
ported gen5 sc
2.8in pulley
TOG headers
Awesome Tom... :occasion14:
Rich
Any plans of going turbo? I heard zzp had some pretty good success with turbo'ing the 3.8 GTP motors.T-Rock;237495 wrote:Got my car finished finally still have some bugs to work out.
L32 connecting rods
oil volume kit
secret big boy cam
Gasket matched LIM
ported gen5 sc
2.8in pulley
TOG headers
2008 Chevy Slobalt
Hope this helps
Hope this helps
Martin
Oil change, New Ground Control extended top hats rear, slight suspension adjustment and re-alignment today.
______________
Eric
97 Cypress Green Integra Ls.
Eric
Ordered bearings. All I have left to get are connecting rods and my short block will be ready to assemble.
99PreludeSh
got the passenger side rear done with Ksport suspension, rotors and pads and got to the drier side and the caliper bracket was seized up. Awesomely enough NO ONE sells that part so I have to replace the entire caliper.
love my rusty looking calipers lol
