Then this...
This is something I got done today...
Now time to go swap tranmissions, degrease, clean, and sand the block and trans and paint them for the re-install.
That brush on stuff isn't as durable as you think, its been chipping off my buddies' element for awhile now. Luckily its easy to touch up.99BlackHatch;236563 wrote:you'll be surprised with what I decided to use on the bay... I figured since the car is going to be caged and used on the track a lot, why not try something different for once and use something that is scratch resistant, durable, and the color I wanted in the bay...
Rhino-Liner.
not sure if thats what you were going for or if you were thinking it would be duller... i used VHT flat alum on my stuff .. it's closer to stock...99BlackHatch;236657 wrote:High temp aluminum is brighter than expected...
