Had the brakes pads on the Fit replaced and changed the oil.
Started the Accord up and looked at it.
Edison Carasio
crx08
fixed my broke timing belt and bent valves. replaced the cylinder head. drove it around. on my DD
stl-imports.com/forums
actually worked on my hatchback lol
motor and tranny are finally together
wiring harness is on
started reinstalling bits in the engine bay
swapped out rear coilover sleeves
cut out rear fender lips
truck bed coated the rear inner wheel wells
cleaned up the suspension
clear coated my intercooler pipes finally
and
ordered new oil pressure gauge
ordered the last an fittings i needed
today im doing more work to it also
and
4Door
broke an axle saturday night, just got it back together a few minutes ago... had to wait for the new axle to arrive at the store...
still cant drive the 92 4Door yet...
but we did fix a few things on it...
RR outer door handle, LF corner light (needed new socket), trunk now latches..
installed hello kitty valve cover lol, took off junk sleeves and installed my Tein lowering springs, installed my Pioneer DEH-400UB head unit, vented the hood, still not sure if im going to swap out the Cernivi's fiberglass hood or not...
still need to install header, Y8 head, gudy cam, SK2 pro mani, AEM fuel rail, AEM cam gear, ARP head studs (need to buy)... thanks again for the help Tib...
maybe doing a FS thread soon...
H.E.A.R.T
crazysol
Xb
New rims and tires (15mm offset, minor poke, minor stretch)
Energy suspension rear bushings kit installed
Honda civic 4dr
Installed koni adjustable shocks on sportline springs
Honda civic 4dr
Barn-Yard Built..
Liquor Assassin
checked the tourque on the head bolts, all are fine, bout to clean and check the wires on my fog lamps and side markers, will have to check the starter wires tomorrow, i need to get some elec tape and some stuff before i go redoing the connections
kikkinasphalt
Rich
Sent my ballasts out.
Still working with the company on the projectors... not liking them wanting me to put the stockers back on ship them the old ones then waiting for them to get them. Then send the new ones....
2008 Chevy Slobalt
Hope this helps
Hope this helps
02Type-S
Got the axles done on the TL-S
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
2002 Acura TL-S
the ed not ef
bypassed clutch start sensor
es rear mount
spacers
alpine type s
cleaned the block and trans
the eg
ex cluster
armrest
clock
tibby
gave it a proud owner and took it to close to stock meaning strpped it kinda
es rear mount
spacers
alpine type s
the eg
ex cluster
armrest
clock
tibby
