SlowCRX
Well swapped those damn famous Honda window washer squirters for some RSX sprayers, and put a OEM drive axle back in.
MidMoMOFO Built
OMR (OneMan Racing) Because we CAN do it ourselves....
Rich
Put the projectors on... still waiting on the hids. And now waiting for a replacement drivers side projector.....
The curse of this car continues!
2008 Chevy Slobalt
Hope this helps
Hope this helps
Rebuilt the LS engine for the sedan, so I can get some decent gas mileage again. Hopefully finishing it this weekend.
thelastloser
valve cover gasket, rear brakes
v-tecivic
stared at my engine wishing it was off the stand and in my car. i need to clean my garage out to make room.
got my competition stage 5 clutch in.
i had a nice loud rattle from my exhaust. i thought it was a heat shield but it was the doughnut gasket on my header that was worn out and leaking. i also found out that my resonator was rusting so it was leaking on a weld as well. i put a clamp on it for now until i get my exhaust redone for my turbo.
97 civic ex turbo
13.1@112
kikkinasphalt
Took my new trans apart for some welding and such
and we built my subframe today
'98 CSVT.. stock
4Door
more pic's of new sub-frame..? looks interesting...kikkinasphalt;226353 wrote:and we built my subframe today
H.E.A.R.T
kikkinasphalt
ill have more tomorrow4Door;226386 wrote:more pic's of new sub-frame..? looks interesting...
'98 CSVT.. stock
kikkinasphalt
Acquired 18" TD Motorsports with fast car tires.
subframe completed.
basically this is a subframe from a 96-99 taurus that has been modified to fit my car. this give me way better steering geometry and handling characteristics.
subframe completed.
'98 CSVT.. stock
