RBs93
Post by RBs93 »
i found out your BOV is an awesome place to stash your spare change and any washers you don't want to lose. ran all new vac lines to just find out it wasn't the problem (troubleshooting FTL!) installed new security!! IE: sitin on blocks!!
RIP: 93eg
zacs2k
Post by zacs2k »
changed oil today, washed and waxed it too
stlgolf.net
Post by Capt'n Obvious »
not my car but worked on alot of cars this weekend
-helped brian swap his heads and install arps and rewire distrib
-made custom mounts for a huge rad in a 93 rx7 with a ls1 swap basicly went from the front of the motor 3 in lower than the stock mounts and almost went up to the core support
-helped paint kevins wheels new hotness suprise 2 hours of taping
4Door
Post by 4Door »
finally installed my ARP head studs and built Ls head...
PP, Crower stage one cams, Crower springs and retainers...
also adjusted the valves, fixed the MSD coil wire and had to do a lil sanding to the connectors in the MSD extreme cap, also fixed a bad ignitor connector...
future mod will be to get a MSD cap that will allow me to use the internal coil again, i seem to have nothing but problems with external coils...
also checking into a set of PIC Performance coil overs and some OEM fog's... not sure if i want clear or yellow tho...
special thanks to Tibby (Matt) and Nate the gate... (Nate the gate is not a member but deserves the shout out, he owns the Rx7 Tibby mentioned)
i will post a few pics later for those who maybe interested...
H.E.A.R.T
Edison Carasio
Post by Edison Carasio »
Place upper control arm and ball joints, had flex pipe and muffler welded up. Sold the Mustang. Replaced headlight and air filter. Washed it and cleaned the windows on the inside.
changed oil
checked distributer
Post by RyanA »
Just did new rotors and ceramic pads all the way around on the Avalanche. It stops A LOT better now...
i put the mudflap on after the bump in the road wanted it more
kikkinasphalt
Post by kikkinasphalt »
Installed new Windshield
Purchased Cams
Purchased Ported Intake manifold
Purchased Ceramic TOB
Purchased 80MM MAF
Purchased Gen 3 Subframe
its getting close.
'98 CSVT.. stock
Rich
Post by Rich »
Ordered the projectors,Hids, and new downpipe
2008 Chevy Slobalt
Hope this helps
