Jacking this from Honda-tech.
I'm picking up a new rear motor mount
New distributor is in the mail
Thats all for me.
Devil Crx
*GMR* CRX Superleggera
RX7- Put in a new tranny mount
Eclipse- filled it with gas.
Which car lolNerrej;198932 wrote:Jacking this from Honda-tech.
Thats all for me.
the coupe' I put gas in and lowered a little more
the hatch I kicked
and the 240 well I gave it a stern look and then realized that was giving me the stink eye back so I left it alone
change oil
bleed brakes 5 times
adjust idle screw
took it to honda to get the seatbelts and they could not
tighten the throttle cable
replace mc
take out a stripped stud
tighten a leaky brake line
add water lol
cc delete
ps delete
test fit wheels
put mudflaps on
found out sb wont fit
adjust tps
found out both rta bushings are ripped
grease shifter
adjust hood latch
i guess thats it
the first two week i had it i did more
keep in mind this car was not running or stoping when i got it
still have to put coilovers on
swaybar
axles
wheels
find out why it wont go full throttle
oh yeah and kick it
do mother fuckin work
adjust idle screw
replace mc
add water lol
cc delete
ps delete
test fit wheels
put mudflaps on
adjust tps
grease shifter
adjust hood latch
i guess thats it
swaybar
axles
wheels
oh yeah and kick it
da9teg
Why would you delete ps? That's seems pretty retarted plus the car does not have a manual steering rack so it's going to be harder to steer and drive meow
Devil Crx
Did you just say meow?
and what is cc delete. its not coming to me right now what that could be?
g-mo
Washed my 240.
Patiently awaiting parts so my GSR can hit the streets again.
Hopefully running the Jetta into a tree. Stay tuned for the new car. LOL
Took the rack off the sedan, washed it a few times, fixed the arm rest console clip so it clips shut now, put my s2 shift knob on, changed the oil, and filled it up a bunch.
Went and seen the new crx, and brought down some parts for it.
