SLOSHONOGO;138691 wrote:well.. you do have a long way to go.
only an idiot would remove their front sway..
when your doing your research you need to complie the data and then make a decision.
you should already know.
1)struts
2) springs/coil overs
3) sways- bigger is better
4) camber plates
5) motor mounts
6) poly bushings everywhere you can put them
7) wheels, wider is better
8) brakes
those 8 are a must for a car to "handle"
now thake that list. and buy the best parts for you car that you can afford, dont buy cheep thinking you can get by. buy quality.
-Ok well I have Kyb Gas so im staying with that
-I have skunk2 springs
-Suspension Technique Front and Rear sway
-Energy Suspension package i thought i saw for like 200 came which abunch of accessories
-Ill prob Stay with just my 17" Adr and put some new tires or my oem si's and new tires
-New oem rotors or brembo drilled and slotted with I guess aem pads or ceramic w\e works
-Neuspeed Strut,Tanabe rear strut bar,Probally Tanabe F&R reinforcement bars which I believe are just tie bars with a dif name?
Thats what I have out and thats why I plan on staying with unless I find better things to go with and I have thought most of that for awhile now but im just now getting around to ordering shit since im farther in school now"meaning its not just started" and I have a little more time.As long as 92fodo comes through on buying the headunit I should have my sway bars and neuspeed bar ordered this week even though theres no rush its still in process of going to the body shop when I get it towed.
