tired of pushing in the clutch upon startup
Post by Capt'n Obvious »
diy
proly should be moved
on a scale of 1-10 i would rate this a 1
on the top of the clutch pedal there sould be a sensor button which gets depressed when the clutch is in un plug and solder the wires together.
thats it now start the car w/o the clutch and make sure its in neutral and should start
Post by RyanA »
Good post. I also recommend leaving the car in 1st gear if you park right in front of your garage or reverse if someone parks behind you. Then, install a remote start....
Post by mike93hatch »
oh my god...... stlhondas brings tears to my eyes. hours of enjoyment. i love it!!!
Post by Gunmetal Si »
^^^^^bbbahahahahahahahah
RyanA;136841 wrote:Good post. I also recommend leaving the car in 1st gear if you park right in front of your garage or reverse if someone parks behind you. Then, install a remote start....
i leave it in 2nd
Post by RyanA »
On an intelligence level of 1-10 I rate this a 1
RyanA;136853 wrote:On an intelligence level of 1-10 I rate this a 1
really? i give it a -5
oh my word.....
SikofFalln
Post by SikofFalln »
Nice post:PDT_att: Here's a thought, if you don't want to push in the clutch upon start up, get an automatic.
3-1-4
99PreludeSh
Post by 99PreludeSh »
no need to be lazy
