Most women are shy about their bodies. Even if you've got the world's
most gorgeous woman (bombcherryjuice) in bed with you, she's going to
worry about how you like her body. Tell her it's beautiful, tell her
which parts you like the best, tell her anything, but get her to
trust you enough to let you go down between her legs.
Now stop and look at what you see. Beautiful isn't it? There's
nothing that makes a woman more unique than her vagina I know I've
seen plenty of them. They come in all shapes, sizes and colors; some
are tucked inside and some thick luscious lips that come out to greet
you. Some are nested in brushes of fur and others are cover with
transparent fuzz. Appreciate your woman's unique qualities and tell
her what makes her special.
Women are a good deal more verbal than men, especially during sex.
They also respond more to verbal love which means the more you talk
to her; the easier it will be to get her off. So all the time you're
petting and stroking her beautiful vagina, talk to her about it.
Now look at it again. Gently pull the lips apart and look at her
inner lips, even lick them if you want to. Now spread the top of her
lips to find her clit. Women have clits in all different sizes, just
like men have different sizes dicks. It doesn't mean a thing as far
as her capacity to orgasm. All it means is more of her is hidden
beneath her foreskin.
Whenever you touch a woman's vagina, make sure your finger is wet.
You can lick it or moisten it with juices from inside her. By all
means be sure to wet your finger before you touch her clit because it
doesn't have any juices of its own and it's extremely sensitive. Your
finger will stick to it if it's dry and that hurts, but you don't
want to touch her clit anyway. You have to work up to that. Before
she becomes aroused, her clit is too delicate to be handled.
Approach her vagina slowly. Women, even more so than men love to be
teased. The inner part of her thigh is her most tender spot. Lick it,
kiss it, and make designs on it with the tip of your tongue. Come
dangerously close to her vagina, and then float away. Make her
appreciate it.
Now lick the crease where her leg joins her vagina. Nuzzle your face
into her bush. Brush your lips over her slit without pressing down on
it to further excite her. After you've done this to the point where
your lady is bucking up from her seat and she's straining to get more
of you closer to her, and then put your lips right on top of her slit.
Kiss her gently, then harder. Now use your tongue to separate her
lips and when she opens up run your tongue up and down the layers of
vaginal flesh. Gently spread her legs more with your hands.
Everything you do with a woman you're about to eat must be done
gently.
Tongue fucks her. This feels damn fine. It also teases the hell out
of her because by now she wants some attention given to her clit.
Check it out. See if her clit has gotten hard enough to peek out of
its covering. If so lick it. If you still can't see it, it might
still be waiting for you underneath.
So bring your tongue up to her slit and feel for her clit. You may
barely experience its presence. But even if you can't feel the tiny
pearl you make it rise by licking the skin that covers it. Lick hard
now and press into her skin.
Gently pull her lips apart and flick your tongue against her clit,
hood covered or not. Do this quickly this should cause her legs to
shudder. When you sense she's getting up there toward orgasm, make
your lips into an "O" and take her clit into your mouth. Start to
suck gently and watch your lady's face for her reaction. If she can
handle it, begin to suck harder.
If she digs it, suck even harder. Go with her, if she her pelvis into
the air with the tension of her rising orgasm, move with her, don't
fight her. Hang on, and keep your hot mouth on her clit. Don't let
go. That's what she'll be saying too: "Don't stop! Don't ever stop!"
There's a reason for that, most men stop too soon. Just like with those women
sucking dick, hell i love 2 have my dick suck i think this is something worth
learning about and worth learning to do well. I know a woman that's a
lousy dick sucker, simply lousy, but she can ride a dick like
nobody I know and she never has trouble
getting a date but give bad head. Men are falling all over her.
But back to your pussy eating session…threes another thing you can do
to intensify your woman's pleasure. You can finger fuck her while
she's enjoying you clit licking skills. Before, during, or after
shell really like it. In addition to the erogenous zone around her
clit, a woman has another extremely sensitive area at the roof of her
vagina. This is what you rub you up against when you're sexing her.
Since your dick is pretty far away from your mouth your fingers will
have to do the fucking.
Take two fingers. One is too skinny and three is too wide and
therefore can't get deep enough. Make sure they're wet so you don't
irritate her skin. Slide them inside, slowly at first then a little
faster. Fuck her with them rhythmically. Speed up only if she does
listen to her breathing.
She'll let you know what to do. If you're sucking her clit and finger-
fucking her at the same time, you're giving her far more stimulation
than you would be giving her with your dick alone. So you can on it
she's getting high on this. If there's any doubt, check her out for
symptoms. Each woman is unique. You may have one who's nipples get
hard when she's excited or only when she's having an orgasm. Your
woman might flush red or begin to tremble.
Get to know her symptoms and you'll be more sensitive lover. When she
starts to have an orgasm, for heaven's sake don't let go of her clit.
Hang in there for the duration. When she starts to come down from her
first orgasm, press your tongue along the underside of her clit,
leaving your lips covering the top. Move your tongue in and out of
her vagina. If your fingers are inside, move them a little too,
gently though things are extremely sensitive right now.
If you play your cards right, you'll get some multiple orgasms this
way. A woman stays excited for a full hour after she's had an orgasm.
Do you realize the full impact of that information? The potential?
One woman was clocked at 56 orgasms at one sitting. Do you know what
effect you would have on a woman you gave 56 orgasms to? She'd be
yours for as long as you wanted her.
Oral sex can be the most exciting sexual experience you can have, but
it's what you make of it. Take your time, practice often, pay
attention to your woman signals and most of all, and enjoy yourself.
Ladies am I lying'?
The Art Of Eaten!!!
modthesol
The Art Of Eaten!!!
cliffs = don't just stare at it, eat it!
Tyler
The Art Of Eaten!!!
american psycho ftmfwmodthesol;133256 wrote:cliffs = don't just stare at it, eat it!
Im a loser
:L33T:
Im a loser
:L33T:
dodgin_it
sharpie
99BlackHatch
The Art Of Eaten!!!
How did I miss this thread.
Everything that was said is correct. Woman love every second of it.
SquadronOne.net
SquadronOne.net
sharpie
The Art Of Eaten!!!
Lol that's why I had to bump this cause I read it the first time he made it and there was a lot of good stuff in it so I had to dig it up today and reread99BlackHatch;176627 wrote:How did I miss this thread.
99BlackHatch
The Art Of Eaten!!!
Sex is fun, but eatting pussy might be better.
SquadronOne.net
SquadronOne.net
getteg
The Art Of Eaten!!!
99BlackHatch;176634 wrote:Sex is fun, but eatting pussy is better.
Fixed, because if you are good she will return the favor.
Save a mouse....eat a pussy!
