motherfing "touchless" carwash
Liquor Assassin
my last car wasnt worth washing, i will NEVER do this again, hand washed from now on
MaSSaCrE
so whats wrong with the bumper just some paint rub off or did it dig in and scrape it up a bit kinda hard to notice and i didnt bother reading to see if someone asked.
Liquor Assassin
a bit of paint rubbed off, no scratches or nicks as far as i can see
Nat X
You guys, the bathroom here is nuts!
slammeds2k
I havnt been in one for years prolly will never do it again bad news!
99SilverCX
when I lived in wentzville, I used to take my car to an automated car was that didn't use the rail, you pull in, then it tells you to stop, then a laser-guided arm goes around the car and washes it, never had any problems because it was a brushless wash, the arm would pre-wash the car, then spray it with soap, then repeat, and it didn't get too close to the car either. The basic was only $5 too.
liquidcooled247
Thats what i use as well no problems. Thats the same thing as every mobil on the run ive been too.99SilverCX;129709 wrote:when I lived in wentzville, I used to take my car to an automated car was that didn't use the rail, you pull in, then it tells you to stop, then a laser-guided arm goes around the car and washes it, never had any problems because it was a brushless wash, the arm would pre-wash the car, then spray it with soap, then repeat, and it didn't get too close to the car either. The basic was only $5 too.
How far is the car off the ground.
subygrl
They have one at the mobile by dave and busters. Thats the one i use too. its completly brushless and its doesn't matter how low your car is.99SilverCX;129709 wrote:when I lived in wentzville, I used to take my car to an automated car was that didn't use the rail, you pull in, then it tells you to stop, then a laser-guided arm goes around the car and washes it, never had any problems because it was a brushless wash, the arm would pre-wash the car, then spray it with soap, then repeat, and it didn't get too close to the car either. The basic was only $5 too.
Jay Z.
I wouldn't use any of them personally. A "touchless" car wash does not use a direct-contact cleaning method, but instead uses acid-based chemicals and high pressure water which in the long run can damage the paint on the car. Many of these places recycle the water thru a filter (to save money). If the filter is clogged/dirty, you could be pressure washing your car with abrasives.
subygrl
Jay Z.;129764 wrote:I wouldn't use any of them personally. A "touchless" car wash does not use a direct-contact cleaning method, but instead uses acid-based chemicals and high pressure water which in the long run can damage the paint on the car. Many of these places recycle the water thru a filter (to save money). If the filter is clogged/dirty, you could be pressure washing your car with abrasives.
I just use it when i need to get my car sprayed off quickly and i don't have time to do it myself.
