I bought a turbo today... Need help
jdmjerry07
Post by jdmjerry07 »
would this do the job for setting boost at 5? If so how do you tell what psi your at?
researched and found out internal is set at 11.5psi and there is different ways to control the boost... via boost controllers seems to be easiest and best way to get what im looking at.
http://www.boostcontroller.com/index.ph ... egory%3D26
Tyler
Post by Tyler »
jdmjerry07;116897 wrote:would this do the job for setting boost at 5? If so how do you tell what psi your at?
that would work for a boost controller, but you would still need to run at least 12psi to open the wastegate and get boost, unless you did what is previously stated, and disassemble the wastegate and put a 5lb spring in it. or what i said and ugrade the internals a tad bit to run 12psi safely and do that. you'd get more power and the possiblity of future mods as well.
or get an external wastegated turbo
Im a loser
:L33T:
You can't turn down the boost on a turbo using an 11.5 pound spring. The lowest psi you can achieve is 11.5psi. Thats why you'd need an external wastegate and a 5 pound spring, not a boost controller.
big pipe
Post by big pipe »
if it is a stock 14b the wastegate SHOULD open at 7psi. the dsm's they came off run 10-12psi because they have a factory boost controller. if it is set for 12 or whatever, you can get a new internal wastegate actuater from a junkyard, or off ebay thatll open at 7psi. your stock internals will last just as long at 7 as they will at 5........if you have a halfway decent tune.
heres a list of junkyard turbos you can get the actuater off http://www.homemadeturbo.com/forum/inde ... opic=27392
Junkyard Turbo Wastegate WG Pressures
this space for rent
jdmjerry07
i have everyone telling me different things here i dont know who to trust lol i just want to not run anything over 7 or 8 so what do i need to do... get a different spring and a different actautor?
02Type-S
Post by 02Type-S »
If I was going to the trouble to turbo my car I would run more than 5 psi. :twocents:
I DETAIL CARS - PM ME
2002 Acura TL-S
Team Arsenic - Vice Pres.
jdmjerry07
on a budget not doing it for speed doing it for experience
honduhej1
Post by honduhej1 »
well this experience is going to cost a lot more than your thinking.....good luck jerry. imo i would sell that shit and experince some new wheels.
ObsesionWitSped
Post by ObsesionWitSped »
honduhej1;116976 wrote:well this experience is going to cost a lot more than your thinking.....good luck jerry. imo i would sell that shit and experince some new wheels.
Meh, I disagree..I'd rather have him experience with the turbo, learn, blow his engine, and learn some more then put new wheels on.
Imagine the vast knowledge you'll gain. :)
Talking about Andy's drop:
jdmjerry07
thank you i agree... i know what im getting into
ObsesionWitSped;116979 wrote:Meh, I disagree..I'd rather have him experience with the turbo, learn, blow his engine, and learn some more then put new wheels on.
