clays elf build
Clayton
clays elf build
Post by Clayton »
Scattered the head Friday. i think it jumped a tooth when the starter was engaged as it didn’t start but ran perfect the night before. Every rocker on intake popped and 2 and 3 had a bent valve. not a big deal i have a spare ls sitting there ready to go and should be in by weeks end. some more good news is i finally got the right wheel bearing in as the front spindles were from a 90 integra and not a 94-01 like originally thought.
Clayton
clays elf build
Post by Clayton »
got the car back from stolles house after he went threw the whole car and redid all of the wiring. it now has a custom harness with a moroso switch panel. so now that i go the car back the fun begins. teh target date to get the car down the track is end of july. maybe even the midnight madness.
i finally got to fix the rear suspension. i am working on putting on the stainless lines and bleed the brakes tonight.
Edison Carasio
clays elf build
Post by Edison Carasio »
Most excellent that you have it back home now.
clays elf build
Post by stolle »
sweet!
Team NOCO Crew Member #2
Leprechaun86
clays elf build
Post by Leprechaun86 »
This thing is the tits.
