clays elf build
Clayton
clays elf build
did alot of work on the car yesterday unfortunatly my camera on my phone is broke so pics will be up soon. i took the engine out of the car without any of the core support in the way the motor and trans slides straight out the front exteremly nice. with the engine and trans out of the car the wiring was completly gone threw and only the neccisites remained. my back up transmission was prepped and cleaned and installed due to the other transmission leaking from the case half seal. the trans thats out will recieve an lsd i already have for it after being rebuilt. the coolant temp sensor for the ecu was found to have a break in the wiring so in turn i hope should help the heisitation between 1-3k. the engine bay was prepped and painted a gloss black and not flat which if you personally know me you will find that as a shock. once back in the vehichle the engine will get a new oil pan gasket the original has a slight drip.
Clayton
clays elf build
engine bay all glossy
took apart one of my transmissions to find that the gear selector shaft is bent to shit. i have another one theat needed a case half seal so i split that one and siliconed a new gasket on.
Focke
clays elf build
Good lord man, how the hell did you/they do that?!
Clayton
clays elf build
stripped, cut, and shaved my valve cover. i freaking love the look
also started on the msd setup
sharpie
eh2_Erik
Edison Carasio
clays elf build
Car is coming along nicely.
99BlackHatch
clays elf build
This really threw me off... I was thinking that was the biggest transmission in the world, or your feet shrank. Lol
SquadronOne.net
SquadronOne.net
Clayton
clays elf build
got these sage racing rear drag shocks last night. they came with 8k springs but i have 16k springs going on there omg so excited.
