My 12.5 comp. street motor
Turtle_Civic
Post by Turtle_Civic »
Rich;284809 wrote:If its an LT1 less than 450whp with just a turbo slapped on..
If its an LS1 475whp MAX without valvespring upgrades and fuel upgrades... And thats at 8-9lbs.
Your wrong. Im putting close to that na on my set up and its a ls1. With a sts rear mount they put a hair over 500 on 10psi stock motor.
Real men dont lift the front wheels.. They power them!!
Rich
Post by Rich »
Turtle_Civic;284882 wrote:Your wrong. Im putting close to that na on my set up and its a ls1. With a sts rear mount they put a hair over 500 on 10psi stock motor.
Stock valvesprings will not hold 10psi. Stock fuel pump will not support over 475whp even with a hotwire kit. And close to 500whp on an ls1? Not without a very healthy cam set of heads and a good intake manifold. And I'm talking at least afr 205's a cam in the 230+ duration range (.600+) lift and a fast intake manifold (at least a fast 90).
Want to try again?
2008 Chevy Slobalt
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Hope this helps
Yes I own 2 slow red chick cars & 1 real car!
Turtle_Civic
The 01-02 im's are the same as the ls6 Im. They flow plenty and yes i have a plenty big cam and supporting mods. We can set here and do this all day if you want. Im just stating a fact. I didn't say i was 500. I said i was close.
Devilchrono
Post by Devilchrono »
Turtle_Civic;284887 wrote:The 01-02 im's are the same as the ls6 Im. They flow plenty and yes i have a plenty big cam and supporting mods. We can set here and do this all day if you want. Im just stating a fact. I didn't say i was 500. I said i was close.
What's your LS1 in?
local asshole (apparently)
2012 GTI
2002 Corvette Sold
2003 Grand Am Sold
Rich
Post by Rich »
The ls6 manifolds flow ok. Not pretty well. The fast(90 102's) and Bbk flow better. but there's a difference between 425whp and 500whp. I'm betting if you have any of those mods done your closer to 425-440. If your on bone stock heads then I'm betting closer to 360-380whp. And even 450whp is nothing to brag about especially with a ls1.
Anyway back on topic. I'm sure this build is a fun one. Though obviously not everyone's cup of tea. But if you have another car with more potential ( your vette) then i understand this build more.
2008 Chevy Slobalt
Hope this helps
Turtle_Civic
All i was getting to was if you can only get 180-190 out of any boosted motor is a waste of money in my opinion. You can buy stock cars with more than that.
Turtle_Civic
Devilchrono;284889 wrote:What's your LS1 in?
Camaro.
sharpie
Post by sharpie »
Turtle_Civic;284895 wrote:All i was getting to was if you can only get 180-190 out of any boosted motor is a waste of money in my opinion. You can buy stock cars with more than that.
So we should all go out and buy veyrons and not mod our cars? That's pretty much what you're saying here is that it's pointless to mod a car if you can just go out and buy one with more power that's stock. People build turbo d's because you can do it for almost nothing. You could build an almost 200whp d series for less than $1,000. You couldnt even swap a gsr into a civic for that much.
Rich
Post by Rich »
Turtle_Civic;284896 wrote:Camaro.
Tell you what when spring comes (that's when I'm getting my car out of storage) I will run your ls1 and we will see how close to 500whp you are
As per the rest of this I think since the op has other cars that an na build on a car could be fun obviously it cost more to make less HP na wise. But if its just for a fun dd I can understand that. Though at 12.5:1 its going to be a minimum of 93 octane and that can sometimes suck. And qt 93 octane is garbage.
2008 Chevy Slobalt
Hope this helps
Turtle_Civic
sharpie;284899 wrote:So we should all go out and buy veyrons and not mod our cars? That's pretty much what you're saying here is that it's pointless to mod a car if you can just go out and buy one with more power that's stock. People build turbo d's because you can do it for almost nothing. You could build an almost 200whp d series for less than $1,000. You couldnt even swap a gsr into a civic for that much.
Wrong again. I had way less than a grand in my swap. Just got to shop for the deals. No you dont have to go buy a super car. Can go buy a new si and get looks and more than a turbo d stock.
