1991 Honda Civic DX sedan
Edison Carasio
Post by Edison Carasio »
gcef89;276934 wrote:what did u do to the two holes on each side of the radiator plug did u plug them or just leave them open?
I don't think I know which holes you're referring to.
Picked up a virgin P28 today for a good price (at least IMO a good price). Too sick to install the header and O2 I picked up, so I guess that and the gauge cluster will have to wait. Gotta order axle seals on next payday.
Edison Carasio
I wasn't feeling so crappy a little while ago, so I did something quick and simple. Installed a Prelude steering wheel. 90-91 I believe. I did a horn mod so the horn works like a 88-91 horn (the Prelude one used a plug instead of the metal conductor ring thing, if I recall). I used to have this in my CRX.
Random pic
This needs installed when I have time and I feel better.
gcef89
Post by gcef89 »
why are you using the 4 wire 02 sensor?
Edison Carasio
gcef89;277216 wrote:why are you using the 4 wire 02 sensor?
Because I'm OBD1
gcef89
Post by gcef89 »
maybe u can help me with mine mine still isnt installed! i still got to get the pigtail
Edison Carasio
gcef89;277337 wrote:maybe u can help me with mine mine still isnt installed! i still got to get the pigtail
The car was wired for a 4 wire plug when I got it. I just need to swap a plug so it's plug and play.
gcef89
Post by gcef89 »
yea my wires running from my ecu to my 02 sensor are just sitting under my dash
Edison Carasio
Broke my muffler Saturday night, so I went to the junk yard and picked up a CRX muffler. The exit pipes stop about 8 inches from the end of the bumper, but otherwise perfect fit.
I guess I'll either live with it, or try to extend them some how or wait till I find a good Sedan muffler in the junk yard. But for $10 it was a fix that can't be beat.
Edison Carasio
Well, I put the CRX Si muffler on last weekend and today I made it look better.
Here is the muffler that came off the car last week. Yuck.
Here's what the CRX Si muffler looked like installed. Fit was perfect, hangers perfect and flanges identical. BUT the exit pipes were 8 inches too short.
So today I went to CarQuest. I they ordered these two 12 inch long 1 3/4 inch to 1 1/2 inch extensions and I bought the clamps. Then I went to O'reilly's for the cheap chrome tips. I wanted the OEM CRX Si look.
Since the extensions were 12 inch and I only needed 8, I had to cut them down.
I put the extensions on the car and marked them with a marker and then went to cutting.
I went all over looking for an exhaust pipe cutter (the little chain strap with the cutting wheels on it) so I could have it for junk yard trips, but no luck. Like an idiot, I gave the cheapie hacksaw a go.
Then I busted out the sawzall.
They went on and lined up just right.
Tightened the clamps down and sprayed the clamp bolts with rust inhibitor so they will be easy to get off in the future. Also did the muffler bolts while I was there.
One of the pipes is down lower :( Oh well.
It's not so noticable on the ground. Here's the end result.
Total cost was $35. The muffler was $10 at Riverside, the extensions and clamps were $15 and the cheap chrome tips were $10.
Edison Carasio
Got a new hood. Not perfect, has clear coat peeling but for $25 it's a much better one than my old one. Old one was rattle canned flat white with rust spots where the paint peeled and had grease stains from getting worked on.
Taxes will be in soon. Gonna do complete gasket set (head gasket, intake/exhaust, valve cover) along with timing belt kit and water pump and I think upgrade to ARP headstuds for a low HP turbo set up NEXT tax season.
