Dot. That's a eff ton of weights too.JustRob;289875 wrote:Good lord, who balanced those? The weight placement on the left wheel looks ridiculous.
lurch's 95 hatch
lurch's 95 hatch
thinkskater007
lurch's 95 hatch
Had the same problem with my brake lights , I just stuffed a nut and bolt in there. Screw the plastic thang.
lurch95hatch
lurch's 95 hatch
i know right?! i thought so too, i got them mounted and balanced at ntb on the rock road. i dont really know how i feel about this.Phate;289878 wrote:Dot. That's a eff ton of weights too.
1995 Civic CX Hatchback (work in progress)
2001 Civic LX Four Door (stock as the day she was born)
lurch95hatch
lurch's 95 hatch
Well, lots of time has passed with some decent progress, but still not road ready. As listed before, did a lot of replacing and renewing. All codes cleared and no problems on that end, but I still have no speedometer and the brakes are super squishy. I need to retry some wiring for the VSS and see if that fixes things, if not its the cluster. And gotta bleed the brakes yet again, and see we're I'm at after that. Over the past month or two I have pieced together an air conditioning setup and have all the lines cleaned up and ready with new gaskets and sensors ready to get installed. Just gotta have some oil put into the compressor and get it wired in and that should be it until the vacuume and charge and hopefully thats that, we shall see...
RYU-CE1
lurch's 95 hatch
nice build progression!! good good build too
lurch95hatch
lurch's 95 hatch
Thanks! These days it's more frustrating than ever, so close but it's still messin with me.
sammybammy
lurch95hatch
lurch's 95 hatch
The best new update is this, thanks stolle
RoyalRice
lurch's 95 hatch
OH yes! Hankooks! :wav:lurch95hatch;289860 wrote:Got new tires for the first time ever, no used tires this time around!
So pretty!
good choice
EndlssMystry
