terry's in bridgeton.SikofFalln;220385 wrote:Who did you end up going with?
What did you improve on your car this week?
v-tecivic
97 civic ex turbo
13.1@112
Silver Knight
fixed.CordiaDOHC;220380 wrote:With help from Mazkid got the new swaybar endlinks installed got the stock manifold and downpipe installed (no crack in the header... dont ask...) Also got my SS gauge cluster installed. No more factory rice wannabe reverse indiglow bs.
Still debating on whether or not the header will go back on.
next up.
08-2010 SS grill
Black headlights
Red and black bowtie for the grill
race Silver Knight.
DC5
2 days ago, did a few things on the HX swap to get it ready to put in:
Rear main seal
Oil pan gasket
Timing belt, water pump, tensioner
Valve cover gasket
Flywheel (OEM)
clutch, pressure plate, TOB and pilot bearing
Heading back to the shop today to do a little cleaning then get the engine/trans on a roller cart so I can get it in the car. Once it's in, I also have all new coolant hoses, new axles, new front rotors and ceramic pads.
Car is a POS but I want it to be a reliable daily I can drive for a few years....
Rear main seal
Oil pan gasket
Valve cover gasket
Flywheel (OEM)
i can do jalljoints lol if you need help bring it by the houseCRX91;220334 wrote:well didnt improve enything just fixing some stuff i messed up new rim jalljoint and outer tie rod
cured its cancer (rust for all you idiots)
97tegra
Well today I flushed and bled the clutch and brakes... discovered the problem behind my ebrake not working.. Oreilly brake caliper seized up!!! So tomorrow I plan to replace that and hopefully pick up my polished slips!!!!
asdf
I washed it for the first time in a couple months, wax held up well. Took a picture.
Rich
Yeah if the header goes back on we can run them sometime. Without it theres flat out no point. Hell theres almost no point with the header :yelrotflmao:Silver Knight;220390 wrote:fixed.
2008 Chevy Slobalt
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Hope this helps
Yes I own 2 slow red chick cars & 1 real car!
Hope this helps
Edison Carasio
Replaced the brake master cylinder on the Accord and had the brake system flushed. Need to do Upper control arm next.
Did nothing on the other two cars (Fit and Mustang).
99BlackHatch
Painted the dash on the hatch and re-installed everything. LED upgrades on everything.
I gave the RL a week off for relaxing
SquadronOne.net
SquadronOne.net
SlowOne.5
new tires
Finds it funny you (all) check my profile multiple times a day. Get a life.
