What did you improve on your car this week?
HondaChild
bounced my way to work. scraped my tie bar on various road bumps. Watched my ECU slide around on the floor as I turned.
Know your roots.
justme5424
integra- took out box of turbo parts and moved it out of the way of the trash can
crx- changed radiator, overflow, wire clean up, wiper change, battery relocation, intake, put air in the tires
welded dump tube, got in wastegate gaskets and oil restricter, welded bov flange up to intercooler pipe, removed a/c and ps brackets off of b16, ordered motor mounts for my swap, ordered obd0 to obd1 conversion harness, ordered distributor adapter harness
and i think thats all lol
90 Honda CRX HF
-B16A Turbocharged
-B16A Turbocharged
J_Jay_B
and you found out something else about your CRV at ted drews! but i no tell!sharpie;199065 wrote:drove the crv and put gas in it
and as for the teg... i installed some amber corners, and front license plate plugs. then that same day i blew a power steering return line. but all is well now. oh and i washed and quikwaxed 4 times... shinny shinny shinny!
LOLZthe individuality of your car is frowned upon... welcome to the honda community
Midori
Benen lower tie bar on the hatch, Golden eagle drain Plug with synpower oil change..
sentra: Nothing lol
sentra: Nothing lol
-'11 Taffeta White CR-V
m6speed
lol it's about all i do to it anymoremodthesol;199052 wrote:i did that a lot
On MY cars, let's see:
Accord wagon:
Pulled power antenna to see if an Integra one would fit. It would not so car is now driving with the antenna hold masked shut until I get a new power antenna.
Put 2 different wheels on it as 2 of them were very slightly bent.
Silver Civic:
Put the Enkei 16's back on it.
Put stock intake arm and air box back on to make it quieter on the highway.
Checked the oil
Filled it up with gas
Black hatch:
Put steelies back on it.
Started taking dash apart to remove.
Avalanche:
Put gas in it.
Hauled a jack over to the shop.
White Camaro:
Nothing.
Camaro Convertible:
Nothing.
CRX:
Nothing.
Accord wagon:
Silver Civic:
Checked the oil
Black hatch:
Avalanche:
Put gas in it.
White Camaro:
Nothing.
Camaro Convertible:
Nothing.
CRX:
Nothing.
B16inside
it got stuck in traffic and i listened to a loose miscellanious bolt rattle and missed my first class
96 swapped dx coupe
B16inside
me and you both dude.:crybaby2:HondaChild;199069 wrote: scraped my tie bar on various road bumps.
96 swapped dx coupe
civicex442
put a new transmission in and fixed my vss
98 EJ6
03 WRX
kikkinasphalt
put gas in it.
:PDT_Armataz_01_41:
its getting goodies in march. but will still be slow.
:PDT_Armataz_01_41:
'98 CSVT.. stock
