car won't start
91beatuphatch
car won't start
Post by 91beatuphatch »
yea i did the y8 mani swap. it is the stock fpr. it did have a b&m one but i removed before i sold it. the fuel rail wouldnt cause anything. i changed the fuel filter before i sold it so i know its good. what you should do is grab a buddy or family who ever can help you and stick your head in the trunk and have someone turn the key to see if you can hear the fuel pump. if you cant then you either have a bad pump or a main relay. in your car its cake walk to change the pump. just remove the back seat and there it is if i remember right. and the main relay is located behind the drivers kick panel under the dash. hope this helps.
