HID kit
HID kit
Post by RyanA »
I'm with Chris on this one. Take everything and switch it side to side. If the problem does not change sides, the issue is with the wiring in the car. The ballasts are pretty sensitive to voltage; low voltage will shut them down. If you have replaced everything and the problem exists, I'm saying you are having a low voltage issue. I have 55w kit on my Cadillac and the driver side sometimes takes a couple times to finally get going. Driver side is the end of the wiring harness; the little amount of voltage drop is enough to shut the ballast off.
I think once you swap components side to side you'll find out that DDM did pretty well by swapping parts for you. Maybe not but I think you'll find this is your problem. AS Chris said, a relay with power going directly to the battery for power feed to ballasts along with a good ground should fix your problem.
Potts1
HID kit
Post by Potts1 »
The only thing I havent swapped sides is where the harness plugs into the factory headlight plug and I cant because that side is where the battery is.
Is this what you guys are talking about?
http://www.ddmtuning.com/Products/HID-K ... ng-Harness
Edit, I read the description on it and it said its not necessary for a high/low kit, the bulbs I have are high/low ones and I dont have the 55w kit, I bought the 35w kit.
-Potts
Potts1
HID kit
Post by Potts1 »
I checked out v-led and their kit looks stupid easy to setup. I like how each side connects to the factory headlight outlet rather than only connecting to one side and dealing with power and ground cables.
-Potts
Bwill9886
HID kit
Post by Bwill9886 »
onecam12sec;284974 wrote:its funny to c ppl pay 200% inflation price on items you egt from ebay from35-75 shipped
It's funny to see people get what they pay for and end up with HID's that don't work and poor customer service.
At least with companies like the one I posted, you know who they are and that they'll stand behind their product.
I'm not saying that people don't get away with spending that little and have no issues. However, I'm not really a gambling man.
2012 Black Ford Focus SES 5 spd. with some mods...
Potts1
HID kit
Post by Potts1 »
V-LEDs doesn't carry hid kits anymore
-Potts
sirricealot
HID kit
Post by sirricealot »
Yeah you dont HAVE TO have the bixenon kit.
The 35 watt kit is the way to go but, I would suggest getting the slim kit anyways.
its $45
2006 Chevy Cobalt SS/NA 2.4L IL: FEERME7
2010 Kawasaki Ninja 250r IL: RUNYON
xbxlive: sirricealot07
ps3: sirricealot7
David Runyon
The4nGuy
HID kit
Post by The4nGuy »
Potts1;285131 wrote:V-LEDs doesn't carry hid kits anymore
Are they out or just not carrying them at all? Because a lot of times, they run out quickly.
'96 Integra LS Coupe - Sold
'97 Integra GS Sedan - DD
Potts1
HID kit
Post by Potts1 »
The4nGuy;285176 wrote:Are they out or just not carrying them at all? Because a lot of times, they run out quickly.
I emailed them asking about the difference between the cheaper and expensive kit and they said they replied saying they no longer carry HID kits, which kinda sucks because they looked stupid easy to install
-Potts
modthesol
HID kit
Post by modthesol »
potts i think you need to calm down
sirricealot
HID kit
Just try ddm again. go with the slim kit, not bulky metal raptor.
its possible you were getting some kind of interference with the raptors
ps3: sirricealot7
David Runyon
