Unknown Maintenece History
Martin
Post by Martin »
SweetEBPSi;194711 wrote:If your not getting any O2 sensor codes, then leave them. Why change something that isn't broke? O2 sensors can be expensive, depending on which one you buy.
Checked, did not have any code for the 02 sensor so I think its ok for now, I can always replace it later if I have a problem with it.
______________
Eric
97 Cypress Green Integra Ls.
Martin
Post by Martin »
JustRob;194767 wrote:You wouldn't think so, but it does. The transmission more moving parts then the engine and is equally important. With any ATF fluid application, you make a good point. ATF is designed to last much longer then standard oils. But anything that takes normal gear oil or Honda MTF, it is just as important to change as your motor oil.
Well my teg has a manual tranny, but I changed the fluid because it had probably not been changed ever in 117k. A little past time I would surmise. Thanks for the suggestion Rob, I might have over looked it had you not suggested it.
______________
Eric
